Summit X670-G2 Series switch latency question
Arthas_Wang
I want to know Summit X670-G2 Series switch latency question
I read the data sheet X670-G2 Series "Less than 600 nanoseconds latency"
this is single device port to port latency value?
1 REPLY 1
Stephane_Grosj1
yes, this is a port to port latency within the switch. You might want also to configure cut-through switching if latency is very important in your use case.
