SummitStack slot unexpectedly resets
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hi all,
I got one X460 (slot-1) and one X440 (slot-2) in a stack, connected using standard SummitStack cables in a ring topology.
Prior to slot-1 unexpected reboot, I had couple of the following entries in a log:
Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
Could this slot-1 reset be due to some wrong (default) multicast configuration ?
Both switches have the same 16.1.1.4 EXOS image.
Regards :)
Robert
Photo of Robert Zdziebło
Robert Zdziebło
  • 646 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hi Robert,
The unexpected reboot and the log you received are probably unrelated.
As far as the log message you received. The x440 switch was designed as mainly a edge switch so its hardware tables are much smaller than the x460. This limits the stack because they share resources. There are some steps that you can take to help minimize the entries in the tables:
https://gtacknowledge.extremenetworks.com/articles/How_To/Multicast-Entry-not-Added-Hardware-Table-Full
The unexpected reboot we would need to see the output before the unexpected reboot log. If there is nothing this typically means that the switch lost power so I would check the power source and the power cable. If you have a syslog server setup this might have more information than the switch.
Let me know if you have any questions.
(Edited)
Robert Zdziebło
Just wanted to add a newline and we have a very short reply :) Delete those two posts above if you can :)
No problem. It has been done. Did you have any questions about my reply above?
Robert Zdziebło
Thank you, Patrick
Here you have a little longer output:
2015-09-11 05:56:10.22 Slot-2: Slot-2 FAILED (1) Dual Master
2015-09-11 05:56:09.66 Slot-2: Node State[5] = FAIL (Dual Master)
2015-09-11 05:56:07.99 Slot-2: pibConduitMasterRcvOneSlot(): failed, rc=-3, errno=0, slot=1
2015-09-11 05:55:56.51 Slot-2: Slot-1 FAILED (1)
2015-09-11 05:55:56.50 Slot-2: PRIMARY NODE (Slot-1) DOWN
2015-09-10 11:57:03.58 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-10 09:56:16.94 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-10 08:28:08.35 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-10 07:25:33.96 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-10 06:08:31.75 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-09 13:49:40.67 Slot-1: Login failed for user root through ssh (10.1.103.101)
2015-09-09 09:59:57.42 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-09 08:59:45.08 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-09 07:59:03.23 Slot-1: IPv4 multicast entry not added. Hardware Group Table full.
2015-09-09 06:51:18.25 Slot-1: Login failed for user root through xml (10.1.103.101)
I'll check the article you mentioned and the power conditions.
I am not sure which slot this output was taken from but can you gather the same output from the opposite slot. You can do this through the master and type in "telnet slot <Other slot#>, login, then run the command accordingly.
Photo of David Rahn
David Rahn
  • 824 Points 500 badge 2x thumb
look at the stacking ports for errors - ( show port stack-port rxerrors)
I had a switch rebooting and it seemed to be related to a bad stacking cable. I could see the rx crc error count climbing every second and getting extremely high then the slot would reboot...
I replaced the stacking cable and the errors stopped and the stack stayed up. - just a thought
Dave
Robert Zdziebło
So far I can say that it is not the cable issue: there are no rxerrors. GTAC case is open.
Photo of Fauriant Tristan
Fauriant Tristan
  • 384 Points 250 badge 2x thumb
Your x460s are linked to other equipements via XGM3-2sf module ?
(Edited)
Robert Zdziebło
No, it is linked through SummitStack module, although XGM3S-2sf module is inserted in X460 (but not utilized).
Robert Zdziebło
Update: following GTAC recomendation, we updated stack to EXOS version 16.1.1.4-patch1-1; waiting for any feedback from customer.
Robert Zdziebło
No info about stack resets - case closed.
Photo of Drew C.
Drew C., Community Manager
  • 37,350 Points 20k badge 2x thumb
Thanks for coming back to update the thread, Robert!
I'll mark this as "answered."
