SummitStack upgrade fails : "No space left on device"
  • Problem
  • Updated 1 year ago
  • Solved
Hi everybody,
I'm upgrading my production SummitStacks from EXOS version 15.1.4.3 to 16.1.3.6.
The upgrade was successful on every stack except one, which fails and displays this error message :
Failed to download image on Slot-7 - tftp: can't open '/scratch/summitX-16.1.3.6-patch1-11.xos': No space left on device
It's a 8-member stack, i tried to launch the upgrade several times and it always fails on Slot 7.
Here is the complete output displayed in CLI :
Slot-1  # download image X.X.X.X extreme/summitX-16.1.3.6-patch1-11.xos vr vr-Default secondary
Do you want to install image after downloading? (y - yes, n - no, <cr> - cancel) Yes
Downloading to Slot-1(Master): ..................................................................................................................................................................................
Downloading to Slot-6(Standby):
Downloading to Slot-5(Standby):
Downloading to Slot-7(Standby):
Downloading to Slot-8(Standby):
Downloading to Slot-2(Backup):
Downloading to Slot-3(Standby):
Downloading to Slot-4(Standby): Failed to download image on Slot-7 - tftp: can't open '/scratch/summitX-16.1.3.6-patch1-11.xos': No space left on device
.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*..***Error: Download image failed (see above error message)
I rebooted the slot 7 but it doesn't solve the problem.
I even tried to remove slot 7 from the stack, do "unconfigure switch all" on slot 7 to put it back to factory default, and then put it back in the stack. The issue is still here.
I wonder if any of you ever faced this problem.
Thanks in advance for the help
Gabriel
Photo of Gabriel
Gabriel
  • 410 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,502 Points 3k badge 2x thumb
You could try BootRom rescue using the summitX-16.1.3.6-patch1-11.xos.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Use-the-Boot-Rom-Menu-to-Download-a...
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,266 Points 3k badge 2x thumb
BootROM rescue, as Dave mentions, will wipe all of the memory on the switch as a part of the process. This is also a valid solution.
Hi Gabriel,
Please first try to run a "ls" and "ls internal-memory" on the switch. Both of these will still retain files after "unconfigure switch all"
Slot-1 Stack.11 # ls internal-memory
-rwxr-xr-x    1 root     0           23427 Feb 25 09:59 show_tech.log.gz
-rwxr-xr-x    1 root     0          153482 Feb 25 09:58 trace.devmgr.1417
-rwxr-xr-x    1 root     0          135079 Feb 25 09:58 trace.nodemgr.1421
-rwxr-xr-x    1 root     0            5622 Feb 25 09:58 trace.vlan.1437
Then, at the prompt, type "rm internal-memory *.*"
Slot-1 Stack.17 # rm internal-memory *.*
NOTE: This will remove all files from internal storage.
Continue? (y/N) Yes
Slot-1 Stack.18 # -rwxr-xr-x    1 root     0          135079 Feb 25 09:58 trace.Slot-1 Stack.18 # -rwxr-xr-x    1 root     0          153482 Feb 25 09:58 trace.Slot-1 Stack.18 # -rwxr-xr-x    1 root     0           23427 Feb 25 09:59 show_tSlot-1 Stack.18 # ls internal-memory
 1K-blocks      Used Available Use%
     49038       716     48322   1%
Then, at the prompt, "ls" and "rm" to any files you feel comfortable removing. I wouldn't remove the configuration file that you're using.
Hope this helps.
Thanks
Brad
Photo of Gabriel
Gabriel
Hello,
Thanks for your help.
When i run "ls" and "ls internal-memory" on the Master slot, it seems no files are using a lot of space.
Then from slot 1 I telnet into slot 7 and run the same commands, i find that internal memory has only 38% space left. I try to erase the content of internal memory but it seems I can't do that from a Standby slot :
Slot-7  > ls internal-memory
-rwxr-xr-x    1 root     0           35645 Feb 24 17:28 old_traces.tgz
    118160     44474     73686  38%
Slot-7  >
Slot-7  > rm internal-memory old_traces.tgz
Remove old_traces.tgz from internal storage? (y/N) Yes
This command cannot be executed on a standby node.
I ran the "rm internal-memory old_traces.tgz" on the Master slot but it didn't remove the files from slot 7.
Is there a way to remove files that are on a standby slot ?
Best regards,
Gabriel
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,592 Points 10k badge 2x thumb
out of curiosity, what switch it is (slot 7)?
Photo of Gabriel
Gabriel
All slots are X460-48p
Gabriel
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
You could enable master-capability on slot 7 then unplug the stack cables. The switch should reboot as its own master and you could they run the rm commands again.
After the files are wiped disable master-capability on the 7 reboot it and and plug the stack cables back in.
Hope this helps,
Photo of Gabriel
Gabriel
Hi David,
I'll try this, and tell you the result.
Thanks for the help
Gabriel
Photo of Drew C.
Drew C., Community Manager
  • 37,388 Points 20k badge 2x thumb
Hi Gabriel, were you able to free up some space and get EXOS to install on that slot?
Photo of Gabriel
Gabriel
Hello,
I managed to remove the slot from the stack, remove files in internal-memory, and apply the new EXOS image.
Thanks everybody for your help
Gabriel
