summitx serious question?
  • Question
  • Updated 5 years ago
Create Date: Jun 25 2012 7:21PM
Now i upgrade summitx350 to summitx 440 and transfer primary.cfg found some question:
1.about vlan config will be missed
2. 1-to-many mirror config will be lost and must manual key in and it tell me
* ........ # ena mirr to port-l 1-7 loop 8
Error: Mirroring VMAN could not be created!
did anyone has this status
(from Hsu_LiPing)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jun 27 2012 9:58AM
Hey helpme
Are the versions of code the same from the 350 to the 440? 440 will be running 15.1 code.
The config should carry over assuming that the ports are the same in number i.e 24 port switch to a 24 port switch. If the version of code is different there may be new capabilities in 15.1 that has changed the command line by adding new commands and that may affect the 350 commands.
Can you give me the command for the mirroring that is not working? I entered what was added in the post and it worked.
P
(from Paul_Russo)
Create Date: Jun 27 2012 5:22PM
ena mirror to portl 1-7 loop 8
conf mirror add port 19
if these command use in summitx it will fail
(from Hsu_LiPing)
if these command use in summitx 440 it will fail
(from Hsu_LiPing)
ena mirror to port-l 1-7 loop 8
(from Hsu_LiPing)
