SuperVLAN don't work on 15.3 ?
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Feb 18 2013 1:17AM
I have Summit x460-24x. After update on 15.3 have a error in log
02/17/2013 23:30:09.85 <Warn:ACL.Policy.IntAppConfFail> Failed to install dynmic acl vlanAggDHCP-f4249-2 for internal applicaton FDB on vlan vl0300-Super1 port 0 .Error: Rule rule has already been applied to inst.
02/17/2013 23:30:09.83 <Warn:ACL.Policy.IntAppConfFail> Failed to install dynmic acl vlanAggDHCP-f4249-1 for internal applicaton FDB on vlan vl0300-Super1 port 0 .Error: Rule rule has already been applied to inst.
02/17/2013 23:30:09.68 <Warn:ACL.Policy.IntAppConfFail> Failed to install dynmic acl vlanAggDHCP-f4249-2 for internal applicaton FDB on vlan vl0300-Super1 port 0 .Error: Rule rule has already been applied to inst.
02/17/2013 23:30:09.67 <Warn:ACL.Policy.IntAppConfFail> Failed to install dynmic acl vlanAggDHCP-f4249-1 for internal applicaton FDB on vlan vl0300-Super1 port 0 .Error: Rule rule has already been applied to inst.
... after entering the configuration commands step by step noticed that the error appears when you add a second subvlan to the switch ... see below
# Module devmgr configuration.
configure timezone name Ukraine 120
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-34
configure vr VR-Default add ports 1-30
configure vlan default delete ports 1-34
enable jumbo-frame ports all
configure sharing address-based custom ipv4 source-only
create vlan "vl0002-SRV"
configure vlan vl0002-SRV tag 2
configure vlan vl0002-SRV protocol IP
create vlan "vl0005-SRV-OSPF"
configure vlan vl0005-SRV-OSPF tag 5
configure vlan vl0005-SRV-OSPF protocol IP
create vlan "vl0055"
configure vlan vl0055 tag 55
create vlan "vl0300-Super1"
configure vlan vl0300-Super1 tag 300
configure vlan vl0300-Super1 protocol IP
enable iparp gratuitous protect vlan vl0300-Super1
create vlan "vl0333-sw-mngt"
configure vlan vl0333-sw-mngt tag 333
create vlan "vl0700"
configure vlan vl0700 tag 700
configure vlan vl0700 protocol IP
enable iparp gratuitous protect vlan vl0700
create vlan "vl0701"
configure vlan vl0701 tag 701
configure vlan vl0701 protocol IP
enable iparp gratuitous protect vlan vl0701
create vlan "vl0702"
configure vlan vl0702 tag 702
configure vlan vl0702 protocol IP
enable iparp gratuitous protect vlan vl0702
configure vlan vl0002-SRV add ports 23 tagged
configure vlan vl0005-SRV-OSPF add ports 23 tagged
configure vlan vl0055 add ports 4, 24 tagged
configure vlan vl0333-sw-mngt add ports 1-20, 23-24 tagged
configure vlan vl0700 add ports 1-20, 25-26 tagged
configure vlan vl0701 add ports 1-20, 25-26 tagged
configure vlan vl0702 add ports 1-20, 25-26 tagged
configure vlan Mgmt ipaddress 192.168.1.1 255.255.255.0
configure vlan vl0002-SRV ipaddress xx.xxx.xx.xxx 255.255.255.224
enable ipforwarding vlan vl0002-SRV
configure vlan vl0005-SRV-OSPF ipaddress 192.168.77.4 255.255.255.0
enable ipforwarding vlan vl0005-SRV-OSPF
configure vlan vl0300-Super1 ipaddress xxx.xxx.xxx.xxx 255.255.255.0
enable ipforwarding vlan vl0300-Super1
configure vlan vl0300-Super1 add secondary-ipaddress 10.100.0.1 255.255.0.0
configure vlan vl0300-Super1 add secondary-ipaddress xxx.xxx.xxx.xxx 255.255.255.0
configure vlan vl0333-sw-mngt ipaddress 172.16.33.1 255.255.255.0
configure vlan "vl0300-Super1" add subvlan "vl0700" - after that all ok
configure vlan "vl0300-Super1" add subvlan "vl0701" - error in log
configure vlan "vl0300-Super1" add subvlan "vl0702" - next error in log
Is it my mistake or bug ?
(from mgbrain)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Feb 26 2013 8:25PM
Better if I bought a Juniper or Cisco, never will acquire equipment Extreme Networks ((
(from mgbrain)
Create Date: Mar 3 2013 3:48AM
mgbrain, was this working fine before the upgrade? I recommend you downgrade to the version of code you were on, and open a case with TAC to investigate. If you have any questions or any difficulties opening a case with TAC, please feel free to post them here.
(from ethernet)
