Switch in Stacking
  • Question
  • Updated 2 years ago
  • Answered
can i install two switch in stack of different models? an SW X250e-48t with an SW X440-48P
Regards
Photo of Daniel Valera
Daniel Valera
  • 734 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
If Summit X440 is 1G uplink model, they can be configured as a stack using SummitStack stacking ports on the rear side. But, Summit X440 is 10G uplink model, they can not be configured as a stack.
Photo of Tony Thornton
Tony Thornton, Extreme Alumnus
  • 1,412 Points 1k badge 2x thumb
Hi Daniel,
As an added resource, below is a link that shows a matrix of different Summit switches, if they can be stacked and any dependencies.
http://documentation.extremenetworks.com/summit_16/Summit_Family_HW_Install/Stacking/r_combining-switches-from-different-series.shtml
Hope this helps.
Tony
Daniel Valera
Thanks Tony but the matrix don ́t show me X250e-48t model
As Kevin mentioned, we would need to confirm if the x440 is a 10G uplink model.  In the 'show switch' output, the Sys Name field it will show the full type of the switch, for example: Summit x440-48p-10G.  If the "10G" is present it will not stack with the x250.  If the switch shows as x440-48p it should stack ok.
Daniel Valera
Ok perfect... the model is x440-48p... thansk bro... regards
