switch not enter administrator mode
  • Question
  • Updated 4 years ago
I have a switch summit x440-L2-24t is remotely managed and authenticated to a radius server. I can not log in as administrator, entry into user mode only.
Previously entered as administrator.
The XOS version is patch1
Someone will have happened this problem?
Photo of Jhonn Bejar
Jhonn Bejar
  • 300 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Jhonn
Can you not log in because the switch can't talk to the radius server or it can get to the server and the account is not working.
Jhonn Bejar
Hello Paul
I go to switch my account from radius server, I logeo, but entered the user mode.
swcdv093.1 >
this does not happen with my other switches.
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Extreme Networks switches have two levels of user privilege:
• read-only
• read-write
Because no command line interface (CLI) commands are available to modify the privilege level, access rights are determined when you log in. For a RADIUS server to identify the administrative privileges of a user, Extreme Networks switches expect a RADIUS server to transmit the Service-Type attribute in the Access-Accept packet, after successfully authenticating the user. Extreme Networks switches grant a RADIUS-authenticated user read-write privilege if a Service-Type value of 6 is transmitted as part of the Access-Accept message from the RADIUS server. Other Service- Type values or no value, result in the switch granting read-only access to the user. Different implementations of RADIUS handle attribute transmission differently. You should consult the documentation for your specific implementation of RADIUS when you configure users for read-write access.
Photo of Stephane Grosjean
Stephane Grosjean
  • 762 Points 500 badge 2x thumb
here's an example for Freeradius, in the users file:
###### Freeradius CLI Authorization Example ######
admin Cleartext-Password := “admin”
    Service-Type = Administrative-User,
    Extreme-CLI-Authorization = Enabled
test Cleartext-Password := “test”
    Service-Type = 0,
user admin has read-write privilege, user test has read-only.
