Switch rebooted,Working fine.
  • Problem
  • Updated 4 years ago
The switch got rebooted and no idea why its happend...
11/02/2014 04:41:22.11 <Info:HAL.Sys.Info> Input voltage to External Power Supply in slot 2 is on. Output enabled.
11/02/2014 04:41:22.11 <Info:HAL.Sys.Info> External Power Supply in slot 2 is present.
11/02/2014 04:41:22.11 <Info:HAL.Sys.Info> Input voltage to Internal Power Supply in slot 2 is on. Output enabled.
11/02/2014 04:41:22.11 <Info:HAL.Sys.Info> Internal Power Supply in slot 2 is present.
Photo of ComraDe
ComraDe
  • 510 Points 500 badge 2x thumb
Posted 4 years ago
Photo of Ravisekar, Rajamanickam
Ravisekar, Rajamanickam, Alum
  • 232 Points 100 badge 2x thumb
  Check the syslog and read the logs exactly befor for the restart. Reason for restart should be power disturbance, process crash log, any loose connections. Check in internal memory that whether you have any core dump file which will be generated during process crash log.
Photo of ComraDe
ComraDe
Thanks Ravi....
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Show debug system-dump
Show log messages nvram
The above two commands will tell
Us if the switch rebooted due to core dump or
Hardware errors if any.
Could you paste the outputs of these two commands ?
Photo of ComraDe
ComraDe
Whether it will affect any traffic..while executing i mean...?
These commands are not service impacting.
Photo of ComraDe
ComraDe
> show debug system-dump
            Slot-1 system dump information
core_dump_info storage: 8/3072 used [EMPTY]
failure: kernel oops
reason: Oops
time: Wed Dec 19 04:27:02 2012
where: Oops:0
$0 : z0=00000000 at=10001f00 v0=c2bbf104 v1=00000000
$4 : a0=00000000 a1=20000000 a2=806f9f18 a3=c2f24f44
$8 : t0=02000000 t1=00010000 t2=8010c398 t3=00000004
$12: t4=7fff6bb8 t5=00000003 t6=00022000 t7=00000000
$16: s0=0000000b s1=c2bbf52c s2=0001869f s3=c3479dd0
$20: s4=00000000 s5=c3149a10 s6=c3479dd0 s7=c3149ac0
$24: t8=00000000 t9=c277f7fc
$28: gp=806f8000 sp=806f9f18 s8=c347ba0c ra=c2bc09cc
Hi : 00000025
Lo : 999999a3
epc  : c277f800 rpacket_setup+0x3b4/0xb14 [linux_bcm_diag_full] Tainted: P
Status: 10001f02
Cause : 00808008
 806f9f18: 00000000 c2f24f44 02458c5e 2661b7b9 02458c5e 00000000 02458c5e 00000001
 806f9f38: 8342b7e0 00000000 00000039 00000001 00000000 fffffbff 81201138 87067684
 806f9f58: 00000000 c160c130 30001f03 001da342 015af470 00001ce0 8ee85da0 801692c4
 806f9f78: 00000000 804b57c0 00000002 804b57f4 804b6c60 00000039 804b6c94 8342b7e0
 806f9f98: 80710000 801694e0 00000000 00000000 00000000 00000000 00000000 806f9fd0
 806f9fb8: 2ac78000 00400000 87067680 81201138 ffffffbf 80107138 00000000 00000000
 806f9fd8: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 806f8000
 806f9ff8: 88359c70 80108bc0 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa018: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa038: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa058: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa078: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa098: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa0b8: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa0d8: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
 806fa0f8: 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad 1bad2bad
log: ... iled, (error -15)
log: <1>CPU 0 Unable to handle kernel paging request at virtual address 20000260, epc == c277f800, ra == c2bc09cc
Version #1 SMP Tue Apr 26 20:09:50 PDT 2 by release-manager@biltsurf.extrem Release 2.6.28.9cougar
Call Trace:
@[<c277f800>] rpacket_setup+0x3b4/0xb14 [linux_bcm_diag_full]
 [<c160c130>] gmodule_get+0x130/0x1d0 [linux_kernel_bde]
Build directory: /home/release-manager/v12_5_3_9/cougar
Kernel Panic.
time: Wed Dec 19 04:27:04 2012
Reason: Fatal exception in interrupt
Caller: 0x8010d6b4 (die+0x124/0x144)
> show log messages nvram
11/03/2014 02:00:30.78 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 02:00:28.78 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 02:00:26.55 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 02:00:24.47 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 02:00:21.60 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:20.22 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:18.21 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:16.20 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:15.89 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:14.13 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:13.88 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:12.10 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:11.87 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:09.86 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:07.85 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:04.07 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:02.06 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:58:00.05 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:58.04 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:56.04 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:36.07 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:34.07 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:32.00 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:29.97 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:57:27.96 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:15.35 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:13.34 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:11.33 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:10.90 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:09.32 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:08.85 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:08.20 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:07.32 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:06.84 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:06.13 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:04.40 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:04.12 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:02.32 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:56:02.01 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:59.64 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:21.54 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:19.54 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:17.49 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:15.48 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:55:13.42 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:51:08.68 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:51:06.67 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:51:04.67 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:51:02.62 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:51:00.62 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:25.31 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:23.32 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:21.30 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:20.36 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:19.28 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:18.34 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:17.28 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:16.34 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:14.28 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:12.28 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:11.65 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:09.63 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:07.62 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:05.61 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:48:03.60 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:47:34.48 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:47:32.46 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:47:30.44 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:47:28.43 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:47:26.42 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:21.14 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:19.91 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:19.10 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:17.86 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:17.10 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:15.86 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:15.06 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:13.80 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:12.96 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:11.78 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:11.65 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:08.99 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:06.98 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:04.97 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:46:02.91 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:45:21.71 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:45:19.70 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:45:17.68 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:45:15.66 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:45:13.65 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:40:32.22 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:40:30.21 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:40:28.16 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:40:26.13 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:40:24.09 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:27.96 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:25.92 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:23.91 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:22.53 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:21.90 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:20.87 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:20.53 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:19.89 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:18.87 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:18.53 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:16.86 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:16.51 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:14.85 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:14.50 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:38:12.84 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:37:38.45 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:37:36.41 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:37:34.40 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:37:32.40 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:37:30.38 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:27.97 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:25.97 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:23.97 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:21.95 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:19.83 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:15.17 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
11/03/2014 01:36:13.14 <Warn:SNMP.Master.AuthFail> Login failed through SNMPv1/v2c - bad community name (10.111.12.151)
Photo of ComraDe
ComraDe
Hi Parthiban,Please note that my switches in stack and the slot 2 got rebooted...
Photo of ComraDe
ComraDe
Hi ,
I have been thinking that the logs which i have shared above is from Slot 1....Since its on stack how do i get the logs from slot 2..???
Log in to slot 1 from the cli telnet slot 2
Then u should be able to run same commands
Also if you know the time stamp for reboot
Please collect show log match time stamp
Photo of ComraDe
ComraDe
            Slot-2 system dump information
System memory depleted.
time: Sun Nov  2 04:32:52 2014
Global Memory Stats:
                   MemTotal:       254656 kB
                    MemFree:         2036 kB
                    Buffers:           16 kB
                     Cached:         6120 kB
               Active(anon):        84272 kB
             Inactive(anon):        84324 kB
               Active(file):         2896 kB
             Inactive(file):         2964 kB
                  HighTotal:            0 kB
                   HighFree:            0 kB
                   LowTotal        254656 kB
                    LowFree:         2036 kB
               Committed_AS:       937060 kB
Top Processes by RSS:
                  cliMaster:        34632 kB
                 snmpMaster:        74800 kB
                        hal:        11828 kB
                      etmon:         3596 kB
                       xmld:         2676 kB
                        epm:         1172 kB
                  emsServer:         1888 kB
                     cfgmgr:         1412 kB
               snmpSubagent:         1436 kB
                       vlan:         1496 kB
                        fdb:         1260 kB
                       eaps:         1716 kB
                      rtmgr:         1232 kB
                      mcmgr:         1484 kB
                        bgp:         1552 kB
                        acl:         1032 kB
Top Slab Caches by Memory Consumption:
                   size-512:         4632 kB
                size-524288:         2048 kB
                  size-8192:         2208 kB
             jffs2_refblock:         1684 kB
          skbuff_head_cache:         1844 kB
                size-262144:         1280 kB
                size-131072:         1024 kB
                 size-65536:          832 kB
                       UNIX:          644 kB
                       filp:          684 kB
                  size-2048:          664 kB
           sock_inode_cache:          636 kB
                     dentry:          592 kB
             vm_area_struct:          516 kB
                 size-32768:          384 kB
                  size-1024:          424 kB
time: Sun Nov  2 04:32:59 2014
                   MemTotal:       254656 kB
                    MemFree:         1976 kB
                    Buffers:           16 kB
                     Cached:         6124 kB
               Active(anon):        83508 kB
             Inactive(anon):        83568 kB
               Active(file):         2920 kB
             Inactive(file):         3044 kB
                  HighTotal:            0 kB
                   HighFree:            0 kB
                   LowTotal        254656 kB
                    LowFree:         1976 kB
                  cliMaster:        34632 kB
                        hal:        11820 kB
                      etmon:         3596 kB
                       xmld:         2676 kB
                        epm:         1172 kB
                  emsServer:         1888 kB
                     cfgmgr:         1412 kB
                       vlan:         1496 kB
                        fdb:         1260 kB
                       eaps:         1716 kB
                      rtmgr:         1232 kB
                      mcmgr:         1484 kB
                        bgp:         1552 kB
                        acl:         1032 kB
                   size-512:         4676 kB
                  size-8192:         2208 kB
          skbuff_head_cache:         1852 kB
                 size-65536:          832 kB
                       UNIX:          644 kB
                       filp:          684 kB
                  size-2048:          660 kB
                     dentry:          592 kB
                 size-32768:          384 kB
                  size-1024:          424 kB
time: Sun Nov  2 04:33:04 2014
                   MemTotal:       254656 kB
                    MemFree:         1976 kB
                    Buffers:           16 kB
                     Cached:         6124 kB
               Active(anon):        83380 kB
             Inactive(anon):        86128 kB
               Active(file):         3036 kB
             Inactive(file):         3084 kB
                  HighTotal:            0 kB
                   HighFree:            0 kB
                   LowTotal        254656 kB
                    LowFree:         1976 kB
                  cliMaster:        34632 kB
                        hal:        11820 kB
                      etmon:         3596 kB
                       xmld:         2676 kB
                        epm:         1172 kB
                  emsServer:         1888 kB
                     cfgmgr:         1412 kB
                       vlan:         1496 kB
                        fdb:         1260 kB
                       eaps:         1716 kB
                      rtmgr:         1232 kB
                      mcmgr:         1484 kB
                        bgp:         1552 kB
                        acl:         1032 kB
                   size-512:         4720 kB
                  size-8192:         2208 kB
          skbuff_head_cache:         1876 kB
                 size-65536:          832 kB
                       UNIX:          644 kB
                       filp:          684 kB
                  size-2048:          660 kB
                     dentry:          592 kB
                 size-32768:          384 kB
                  size-1024:          424 kB
Hello it looks like memory depletion.
Stop unnecessary snmp polling to the switch.
Add ACL to allow snmp access from specifi source.
From the logs there is lot of snmp failures.
From show memory it's clear that snmp process is high.
For a temporary workaround you can restart
Process snmpmaster ... The reboot will occur only when free memory goes below 20 mb.
Photo of ComraDe
ComraDe
Does it have any permenent solution..?
Adding ACL would help to resolve the issue..?
Yes we can get a permanent solution .
We have to raise this issue to tac .
Show tech all
Show memory ( 5 times)
With one hour interval
Photo of ComraDe
ComraDe
Hi Parthiban,
There is a doubt in this.......
You have mentioned if the memory free goes below 20 MB it will get rebooted.As per the below log the free memory is 2MB...and SNMP process hitting 74 MB......so how it will affect now....reboot again...
Stats:
                   MemTotal:       254656 kB
                    MemFree:         2036 kB
                    Buffers:           16 kB
                     Cached:         6120 kB
                  HighTotal:            0 kB
                   HighFree:            0 kB
                   LowTotal        254656 kB
                    LowFree:         2036 kB
                  cliMaster:        34632 kB
Less than 20 mb there will be alert when it hits 2 mb it will reboot
Photo of ComraDe
ComraDe
I have configured all my SNMP configurations on slot 1 then why slot 2 hitting high on SNMP process and reboot..?...Can you help me here...
Photo of ComraDe
ComraDe
Thanks for your prompt reply...Let me check whether i can restrict SNMP by using ACL and restart the process....
Photo of ComraDe
ComraDe
I have configured all my SNMP configurations on slot 1 then why slot 2 hitting high on SNMP process and reboot..?...Can anybody help me here...
There are reasons for snmpmaster process high . I would suggest to open a tac case for this issue to be investigated
