Switch with 1gb and 10gb ports
James_Red1
New Contributor III
Hi Community,
I would like to know if there is a 24-port extreme switch with below port config:
12 ports electrical 1Gb
12 port SFP+ 10Gb
Thank you!
9 REPLIES 9
Bin
James_Red1
New Contributor III
thank you all for the suggestions!
dflouret
James,
As AlexandrP mentioned, you need a Summit X670 switch (either X670-48x, X670V-48x or X670-G2-48x-4q) with 12 10/100/1000Base-T SFP transceivers (these will only operate at 1G). This is a 48-port switch, so you will have an additional 24 SFP+ ports, but is the only one that will give you the port combination you need.
Doug_Jaquays
I don't think any purple switches can meet your config requirements. You technically might be able to get there an x460-G2 and the VIM-2q module with fan out cables, but that isn't really what you're asking for.
