Switch x440t extreme problem with ports
  • Question
  • Updated 3 years ago
  • Answered
Hello! I have some problems with some ports of my switch x440t. How can i discover if my ports are failing? exist some command?
thanks!!!
Photo of Andrei Tunes
Andrei Tunes
  • 274 Points 250 badge 2x thumb
Posted 5 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Andrei
Not sure what problems you are having with the ports but if you look at the stats for TX and RX and you are seeing errors what I would then do is run Extended Diagnostics on the switch using the run diagnostics extended.  This will impact the switch so please do it after hours or in a maintenance window.
Thanks
P
Andrei Tunes
Hi! Some ports of my switch doesn't respond. Even the leds don't light. But, I can't find a command what say something like "Problem in port x". Sorry about my english....
Thank you!
Photo of Paul Russo
Paul Russo, Alum
running the diagnostics should show any HW issues.  If the switch is still in default just do a show vlan default or show default and see if the ports are enabled. they will have a ! if they are disabled.
If they are enabled then I would recommend opening a TAC request.  The 440 has LLW that will replace the HW if it is bad.
Thanks
P
Andrei Tunes
Thanks to your help!!! The ports are enabled, but doesn't work. Sorry about my ignorance, but what is LLW and HW?
(Edited)
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
we have seen on EXOS 15.1 and EXOS 15.2 base software version for X440 switch, some ports stops forwarding the traffic at random interval of time. those port never learn mac address. I would suggest to upgrade the switch to EXOS 15.,3.1.4 patch 1-33 and see if you are facing the similar issue.
Andrei Tunes
Hello! We have on switch the EXOS 15.3.2.11 parch1-2. Maybe I can to upgrate for 15.4... What do you think?
Photo of Paul Russo
Paul Russo, Alum
Hey Andrei
This depends on your service level.  If you do not have a service level then you can only get the level of code that was out when you ordered your equipment.  I would call TAC and see if they can help diagnose the issue it will be the fastest resolve time.
P
Andrei Tunes
So, are you think that my equipment have a hardware problem? Why the diagnostic extended can't find nothing?
What I need to do?
Thank you again!!
Photo of Paul Russo
Paul Russo, Alum
Andrei
LLW stands for Limited Lifetime Warranty.  LLW is for the Hardware so if there is a physical issue it will be replaced.  I would recommend Sumit's suggestion first.
Thanks
P
Andrei Tunes
Thanks again!! You are helping me a lot!
So, i run the diagnostic extended and everything is ok, but my ports 1-9 dosen't work yet. look the diagnostic:
[KSW-SFB-CENAFLOR.1 # run diagnostics extended
Running Diagnostics will disrupt network traffic.
Are you sure you want to continue? (y/N) Yes
SW-SFB-CENAFLOR.2 #
The system is g
Sending SIGKILL to all processes
Requesting system reboot
Extreme Networks
Alternate BootStrap Image
Starting CRC of Default image
Using Default image ...
Extreme Networks
Default BootLoader Image
DRAM Post
Press and hold the <spacebar> to enter the bootrom.
Copyright 2003 - 2012 Extreme Networks, Inc.
Loading EXOS Diagnostics ... |/
Running Image ...Decompressing diagnostics...
Initializing operational diagnostics...
Running Power On Self Test...(Extended mode)
Test i2cenviron                   - PASS
Test nvram                        - PASS
Test internal compact flash       - PASS
Test sdram                        - PASS
Test loopback eth                 - PASS
Test loopback pci                 - PASS
Test loopback mac interface       - PASS
Test loopback phy copper          - PASS
Test loopback phy fiber           - PASS
Test snake interface              - PASS
Test asic0 reg                    - PASS
Test asic0 mac                    - PASS
Test asic1 reg                    - PASS
Test asic1 mac                    - PASS
Storing diagnostics result into EEPROM.
Diagnostics completed.
Waiting for reboot...Restarting system.
What is happening?
Sumit Tokle, Alum
If you have upgraded the switches to EXOS 15.3.1 patch 1-33 and still seeing the issue, open the case with TAC.
Andrei Tunes
I upgraded my switch, but not solve my problem... What I don't understand is why the switch don't show me that it have a problem??
Thank you!!
Photo of Paul Russo
Paul Russo, Alum
Hey Andrei
The extended diagnostics cover a lot of the HW testing but there are some things it may not catch.  TAC can also look at the Show Tech file or see if there are any dumps to help determine the issue.
Thanks
P
Andrei Tunes
Hey! Thanks!!
I found this errors in logs:
<Erro:Kern.Error> bcm_custom_extr_eee_config_set(16178): eee set enable error, port=8, unit=0, enable=0, rv=-16
<Erro:HAL.Port.Error> Failed to set eee config on port 8, rv = -16
Sumit Tokle, Alum
open a case with TAC :)
Andrei Tunes
Thanks...
Andrei Tunes
Thanks everyone!! How can I put 'Answered' in this topic?
Sumit Tokle, Alum
You can comment it on this post itself if it's regarding the X440 port issue else I would suggest to create new post.
Photo of zain mallick
zain mallick
  • 318 Points 250 badge 2x thumb
my problem  is  that ,when i connect the switch(summit x440) with pc's the  switch is not working but the lights of all ports are green....
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 38,688 Points 20k badge 2x thumb
Hi Zain,
Welcome to The Hub. I'm creating a new thread for this for better visibility. Please follow the new thread and provide us with some more information about your network.
Please reference the new conversation here: Problem connecting PCs to X440
