Switchs B and A series default trap
  • 2
  • Question
  • Updated 4 years ago
  • Answered
Hi, a question about switch B and A series: when trap generation is enabled in the switch, how can i know the list of trap generated by default ? I cannot find this list in the manuals.
Photo of Esteban
Esteban
  • 110 Points 100 badge 2x thumb
Posted 5 years ago
  • 2
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,620 Points 5k badge 2x thumb
Official Response
I do not have a list, but if you run "show config all" then you will get all your switch settings (including defaults). Then you can search in the text for "trap". You will see what traps are enabled and what traps are disabled in your config.
good luck
Zdenek
