swtich not recognize commands
  • 2
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Nov 20 2013 6:17PM
The problem I have is that the switch does not recognize any command in the hyperterminal shows me the text I write, to give enter nothing happens, and try what it says below, and does not work:
Otherwise, you can clear the entire configuration and start from scratch by establishing a console session (8/n/1/xon/xoff) and holding the spacebar down when a prompted to do so appears on the console output. Watch the console screen for the message as the switch comes up. It's easy to miss the first time, so it might take a few reboots to catch it. You will first see a message to hold the spacebar to enter the bootstrap, which you do not want. Once in the bootrom type "config none" and then "reboot". The default configuration will be used, so the "admin" account will have no password. Be sure to save the config immediately to overwrite anything in the primary.cfg file.
Please some help!!!
(from Carlos Manuel_Calderon)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
  • 2
Create Date: Nov 22 2013 9:58PM
hello Ciceron
Let me make sure I understand.
You are connect via the console.  you can login to the account and once you are at the prompt you can type in a command but when you hit enter it does nto execute the command nor does it drop you to another command prompt?
Is that correct?
Can you try using putty or some other terminal emulator over hyperterminal? it really isn't the best one to use.
P
(from Paul_Russo)
