Sync Device Not Working
  • Question
  • Updated 5 years ago
  • Answered
Create Date: May 30 2013 3:06PM
I'm trying to sync two switches that I've added to Ridgeline. Version is 3.1 SP3.
The switches are both x670v-48x's running code version 15.2.3.2 patch1-4.
When running "Update device" both switches get to the "reading port data" process and then fail with the message "Sync Device Error for "Switch name""
I don't get this issue with other models of switches. I've looked through the Ridgeline release notes and nowhere does it say anything about sync issues with this particular model of switch.
I'm now at a loss. Really need to be able to manage these switches correctly. Rebooting the switch or server does nothing.
Thanks
Ian
(from Ian_Broadway)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 2 2013 4:49PM
not sure if you ever got this resolved but sometimes it will go ahead and sync if you force it to use snmpv3... if that does not work then look at the config of the switch you are trying to sync by doing a show config snmp ..... if there seems to be alot of extra entries created by ridgeline you may need to manually remove them... good luck
(from robert_jacobs)
