Syslog display wrong information
  • Problem
  • Updated 2 months ago
  • In Progress
  • (Edited)
I have configured my switch to send messages to the syslog server (XMC).
configure syslog add <IP-XMC>:514 vr VR-Default local0
configure log target syslog <IP-XMC>:514 vr VR-Default local0 from <IP-SWITCH>
enable log target syslog <IP-XMC>:514 vr VR-Default local0
configure log target syslog <IP-XMC>:514 vr VR-Default local0 filter DefaultFilter severity Info
configure log target syslog <IP-XMC>:514 vr VR-Default local0 match Any
configure log target syslog <IP-XMC>:514 vr VR-Default local0 format timestamp seconds date dd-mm-yyyy event-name none tag-id tag-name
The information I see in syslog is see screencopy
I see the wrong info at source , client an the information isn't right (starts with minutes and seconds).
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,712 Points 3k badge 2x thumb
Posted 2 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,620 Points 5k badge 2x thumb
Hi.
I guess you migrated from windows to linux or Virtual machine or opposite or simillar.
The log file where the text syslog is present is parsed based on configured setting = xmc does expect some format.
You can change the parsing . If you go to OneView -> Alarms & Events ~> the last tab (if I remember well Log Manager) -> then you need to find syslog and edit the format.
Regards
Z.
Johan Hendrikx
nop. did not help for the syslog messages that XMC receive from switches.
(Edited)
Is the issue present also for new messages comming?
Do you have kind of syslog proxy/forward between your switch and XMC?
Johan Hendrikx
We just finished changing hardware to G2 switches and I ve migrate XMC from windows to an apliance.
Firmware is 22.4.1.4
I don't use a syslog proxy
Messages from EWC looks oke
(Edited)
Johan Hendrikx
Logging from syslog:
How come ther is a difference in format ??
EWC:
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) events: Radius Client Radius Response:  Accepted: UserID:48:43:7C:2A:DB:3C, Client MAC:[48:43:7C:2A:DB:3C] 3
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) events: Radius Client RADIUS server authenticated login (Access Accepted). 3
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) dhcpd: DHCPREQUEST for 10.254.16.11 from 48:43:7c:2a:db:3c via csi6
Switch: (firm. 16.1.2.14)
<5>Jul 27 15:25:55 27-07-2018(10.2.112.209) 15:21:31 vlan.ms[1476]: Port 5 link down
<5>Jul 27 15:26:24 27-07-2018(10.2.112.209) 15:22:01 vlan.ms[1476]: Port 5 link down
<5>Jul 27 15:26:36 27-07-2018(10.2.112.209) 15:22:12 vlan.ms[1476]: Port 5 link down
(Edited)
Johan Hendrikx
I noticed that when you change the syntax the output is different.
configure log target syslog 10.2.112.1:514 vr VR-Default local0 format timestamp seconds date none event-name none tag-id tag-name.
<5>Jul 30 08:22:56 10.2.128.250(10.2.128.250) 08:18:30 vlan.ms[1933]: Port 3 link down
What is the right syntax
(Edited)
