SYSLOG interface
  • Question
  • Updated 5 years ago
Create Date: Jan 4 2013 12:05AM
Is there a way to specify the interface using which the switch will forward the syslog messages to the server???
The reason being that I have only some VLANs that are permitted across the firewall to use port 514. As a result the switch with only those vlans or one of those vlans log  messages but my core switches do not as I am assuming they are using VLANs that are not allowed across the firewall.
Is there a way to configure the switch in a way that it forwards the messages to syslog server using a specific VLAN IP address.
Note : I am using vr-default
(from Arpit_Bhatt)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jan 7 2013 10:52AM
configure log target syslog {ip address} from {vlan ip address}
(from Jamie_Bedford)
Create Date: Jan 8 2013 1:46AM
Thanks buddy...for some werid reason it resolved my issue coz the firewall was wide open and it should have worked
(from Arpit_Bhatt)
