System does not have enough power left to support card x.
  • Problem
  • Updated 2 years ago
  • Solved
Hi folks!
I've tried to expand number of SFP ports in quite old one Alpine 3802 (45064) switch using second GM-16X3 card (45121) and it comes up with this fault:
System does not have enough power left to support card 2.
This unit is powered with 2 internal DC PSUs fed from >10A sources each.
ExtremeWare Error Decoder is not much useful:
1 Check the power supply. - done
2 If necessary, replace power supply units. - PSUs are embeded
3 If the problem persists, contact Technical Support. - unsupported unit
There's no
show power
command in this unit.
Alpine3802:37 # show slot
Slot 1 information:
    State:              Operational
    HW Module Type:     GM-16X3
    Configured Type:    GM-16X3
    Gigabit ports available:
        Link Active:    01 02 03 04 05 06 07 08
                        09 10 11 12 13 14 15 16
        Link Down:
Slot 2 information:
    State:              Powerdown
    HW Module Type:     Empty
Slot 3 information:
    State:              Empty
    Configured Type:    Not configured
Whenever I remove the card from the first slot - the second one comes up ok.
Any ideas? I'm stuck with this problem, as I need to keep this boy working.
Thanks,
Michal
Photo of Michal Siemonski
Michal Siemonski
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of EtherMAN
EtherMAN, Embassador
  • 6,960 Points 5k badge 2x thumb
was not designed to run 2 16 port cards.... Been in your spot many year ago also... You would need to go to one of the bigger chassis to run multiple 16 port cards.... Just out of curiosity what keeps you from going to say a 460 or a 440 X switch with 24 ports of SFP and only one rack unit???
Photo of Drew C.
Drew C., Community Manager
  • 39,440 Points 20k badge 2x thumb
And MUCH less power consumption :)
Michal Siemonski
This unit was bought as a part of the project, founded by ministry of education and we need to keep it running still. Working fine for many years anyway. Sad that we can't expand the number of SFP slots. Thanks for replies. All the best!
