Tagged vmans, assigned to sharing, converts to untagged after removing port from sharing
  • Problem
  • Updated 2 years ago
  • Solved
  • (Edited)
Easy to reproduce:
# enable sharing 33 grouping 33-35 lacp
# create vman "v9"
# configure vman v9 add ports 33 cep cvid 9
# show vman v9 | include 33
     *33g: CVID 9
# configure sharing 33 delete ports 35
     Untag:    *33g
Image   : ExtremeXOS version 16.1.1.4 by release-manager
          on Fri Jun 12 17:47:56 EDT 2015
A bug? Or feature?
Edit: Fixed Formatting
Photo of Max Nirin
Max Nirin
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Max,
I was able to reproduce this as well. I tested in EXOS 15.3 also, and did not see this behavior, so I'm leaning towards it being a bug.
I'd suggest opening up a case with GTAC so that we can take a closer look at this and bring it to engineering as needed.
-Brandon
Photo of Max Nirin
Max Nirin
Good day, Brandon. Thank you for reply. I have opened a case 01175058.
(Edited)
Photo of Korsovsky, Konstantin
Korsovsky, Konstantin, Employee
  • 686 Points 500 badge 2x thumb
Hi Max,
 described behavior is due to xos0062255. At the moment the fix is available in EXOS 16.1.2 and will be included in future 15.6, 15.7 GA releases. Here is a newly created KB article about the same:
https://gtacknowledge.extremenetworks.com/articles/Solution/CEP-configuration-is-missing-after-addin...
