TCP/UDP Port based Rate Limiting on EOS
  • Question
  • Updated 3 years ago
  • Answered
Hi All,
I am trying to wrap my head around something and was hoping that someone out there could assist me in the right direction.
This will be for a POC.
Objective:
Specific Layer 7 ports (80 or 123 or 587 as examples) rate limited (ingress [bandwidth shaping]) on an EOS switch - probably a C5 on a single interface (all network traffic passes past this interface)
I assume that the C5 will need the extra Routing license ?
I am getting a bit lost and think I might be totally over-complicating it in my mind.  I was thinking that this could be done with extended ACLs and route-maps but I cant find examples of rate-limiting route-maps ?
Is this even possible ?
thanks !
Photo of Dewald Botha
Dewald Botha
  • 674 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Christoph
Christoph
  • 1,812 Points 1k badge 2x thumb
Hello Dewald,
I would suggest to use EOS policy. There is no routing licence needed.
Kind regards
Christoph
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
You could do this with policy.  You would use layer 3 ip socket source/dest or layer 4 TCP/UDP rules to classify traffic then apply whatever QoS/rate shaping etc..  Not 100% sure of the rate shaping capabilities of a C5.
Dewald Botha
thanks ! - I will check out Policy !
