Temperature Threshold in Degrees C
  • Question
  • Updated 2 years ago
  • Answered
Hi
I have been told that Netsight 7 now can do the overheat threshold alarm in Celsius or Farenheit. Where is this set, i can't find it.
Photo of Justsomebodi
Justsomebodi
  • 1,572 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,734 Points 5k badge 2x thumb
Hello,
We have an open change request to add this feature into NetSight. From what I can tell it has not been released yet. Do you know who told you it's now possible in NetSight 7?
Thanks
-Ryan
Justsomebodi
Hi
I received an email that the fix had been released as I had a open GTAC case for it. I assumed it was fixed in rel 7 of Netsight.
What case number was it opened under? I can check to see what the status is.
Thanks
-Ryan
Justsomebodi
Hi
Case no:01152800
Hello,
That case has been closed pre-maturely. Currently this fix is targeted for 8.0, but this is subject to change.
Thanks
-Ryan
