temperature threshold
  • Question
  • Updated 4 years ago
The switch works abnormally for a period time. One time it lasts about 3 hours and the other time  it lasts about 1 hour. During this period, the computers can’t ping  each other. After  this period time, the switch get right auto without any manual action. The logging buffer shows nothing about this err. But “show support” notes  “System temperature has exceeded the Upper Threshold limit.” and “System temperature has come down below the upper threshold limit”.  Is this error  resulted from the high temperature ?  and this A4 has about 30 static routers.  Do so many static routers lead to the switch work  high loading and high temperature ?
Photo of wangxiaohui
wangxiaohui
  • 90 Points 75 badge 2x thumb
Posted 4 years ago
Photo of rbrt_weiler
rbrt_weiler
  • 834 Points 500 badge 2x thumb
Those log messages show that it is getting too hot for the switch. I guess you should cool down the room where the switch is located - precise temperature limits can be looked up in the data sheet.
(Can't say anything about the routes, though 30 doesn't sound that much.)
-R
