The "​​configure forwarding switching-mode cut-through" command is absent in 16.2 and 21.1.3.7
  • Question
  • Updated 7 months ago
  • Answered
Hello, everybody,
I've found an article "https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Prepare-An-EXOS-Switch-Optimally-Fo..." where ​​"configure forwarding switching-mode cut-through" command is mentioned. The article is for all Summits and for all EXOSes.
But when I try to say "configure forwarding switching-mode" I got an error message.
X440-8p.2 # configure forwarding ?
  L2-protocol           L2 protocol
  hash-algorithm        Set hardware hash table algorithm for layer 2, IP local host and IP multicast entries
  hash-recursion-level  Maximum number of L3 HW dual-hash buckets to modify to make room for a new IP unicast or multicast entry.
  ipmc                  IP Multicast
  sharing               Configure settings for ECMP route sharing as well as load share group distribution
X440-8p.2 # configure forwarding switching-mode
%% Invalid input detected at '^' marker.
X440-8p.3 #
The same thing is on X460-G2 with 21.1.x.x EXOS.
Could you please tell me what is wrong?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 1 year ago
Photo of Ole
Ole
  • 330 Points 250 badge 2x thumb
Hi Ilya,
the command is not support on all Switch Series. Have a look at the following atricle:
http://documentation.extremenetworks.com/exos_commands/EXOS_All/EXOS_Commands_All/r_configure-forwar...
Regards
Ole
Ilya Semenov
Thanks, there is an error in the article, now I see.
Photo of M.Nees
M.Nees, Embassador
  • 9,262 Points 5k badge 2x thumb
Related to this question - here the supported platform:
(copied from EXOS 22.4 Release Notes)
Cut-through forwarding mode supports only on 40G ports of X770 and
X670G2,X870 and X690 platforms. Also supports on 100G ports of X870 and
X690 platforms.
Can some explain why only 40G ports are changed to cut-through not the other 10GB Ports?
This is not customers expectation. If i decide to speed up server latency with cut-through i also need this faster switching methode on 10GB Ports too.
If some can explain that or show some responseable reasons for that limitation - it will be very welcome.
Regards
