The processing of Jumbo frame and L2 forwarding
Yuki_Nakamura
New Contributor II
Hi
Please let me know about the processing of Jumbo frame.
I think that the EXOS switch is dropped the jumbo frame, when EXOS switch receive the jumbo frame(larger than 1522 bytes) on condition that disabling is jumbo-frame function.
(This communication is Layer 2.)
Is my understanding of this correct?
What is the condition for Rx-Over to count up?
I understand that Rx-Over is outputting on show ports rx-error when jumbo frame is received.
Is Rx-Over outputting even if jumbo frame function is enabled?
2 REPLIES 2
Sushruth_Sathya
As Karthik said, when Jumbo frame is received in a Jumbo-disabled port, EXOS will drop the packet. However, when we receive a Jumbo frame and it has to egress out of a Jumbo disabled port, EXOS will fragment the packet and send it out.
Karthik_Mohando
Hi Yuki
I hope you already had an answer for this one but still here is it.
https://extremeportal.force.com/ExtrArticleDetail?an=000086630&q=
Yes the packets will be dropped if Jumbo frames are disabled in the switc
