There is a command in EXOS for "interface vlan x" "shutdown"?
  • Question
  • Updated 1 year ago
  • Answered
I want to disable the IP of one vlan. In EOS is pretty simple
interface vlan X
shutdown
But I haven't found anything similar in EXOS. There is
disable ipforwarding
but it's not the same, as the IP is still up and running.
Any idea?
Photo of Toni Comerma
Toni Comerma
  • 230 Points 100 badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
unconfigure <vlan> ipaddress
Photo of David Coglianese
David Coglianese, Embassador
  • 7,208 Points 5k badge 2x thumb
The above is the only solution I have found. It does add extra work when you want to bring the IP interface back up.
It would be nice to have the option of disabling the interface and simply enabling it down the road. Are there any plans to make that available in the future.
Thanks,
Toni Comerma
Thanks, but this is not exactly the same. It deletes the configuration. If you do this, there is no way to enable it again. You have to recreate the configuration (IP, mask, gateway). And I'm trying to avoid it.
Kind regards,
Toni
Photo of OscarK
OscarK, ESE
Disable vlan <vlan>
Would that be what you are looking for ?
Toni Comerma
disable vlan <vlan>
does not work is you have some L2 protocol active. On top of that disables switching, which is something I don't want.
Thanks
We tried to do this for a cut over and found the gear was still choosing to forward traffic to the disabled VLAN. So we ended up having to delete the IP and then add it back when we where ready to bring a building online.
This was a while back, I think summer of 2015. We felt it was a bug and talked about reporting it but I do not recall if we did, and I do not know if the functionality with this was improved.
Thanks,
Photo of M.Nees
M.Nees, Embassador
  • 9,620 Points 5k badge 2x thumb
i am also needing a shutdown command for L3 interfaces ... like it many other vendors provide this.
Regards
Photo of M.Nees
M.Nees, Embassador
Opening a GTAC Case and started a Feature Request getting such a basic functionality.
