Tips to find root cause of problem
  • Question
  • Updated 5 months ago
  • Answered
latency of some computer in one specific vlan, Not all of the computers are affected, but it is increasing... checking traffic on ports, no messages on Core. If I move the pc to a different vlan the problem is solved for that computer, but still happening on the vlan. Please help
Photo of Karina Del Moral
Karina Del Moral
  • 804 Points 500 badge 2x thumb
  • desperate
Posted 5 months ago
Photo of Robert Cummins
Robert Cummins
  • 452 Points 250 badge 2x thumb
Have you checked for:
 - port error counters
 - client side error counters
 - counters in general
What does a tcpdump from a client show?
How are you measuring the latency and how much of a change are you measuring?
Karina Del Moral
Yes... I check.. but nothing.. on the counters all normal, but a did a sh fdb port on all the ports in the affected vlan... and found a switch connected, as soon I disable the port the other pc's normalize... now we need to check if it is the switch or a pc connected to  it generating the traffic...
Thanks
Robert Cummins
:-)  I suspect your network was looped with that other switch and you were encountering a broadcast storm.   This would be apparent in a tcpdump from the client; you'll see the same broadcast packet appear in the dump multiple times.    Have you enabled erp on the switch?   I think it's erp; erp will automatically shutdown ports when it detects a loop.
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,300 Points 2k badge 2x thumb
