tNetTask -Searches bringing up wrong results & GTAC suggestion
  • Question
  • Updated 2 years ago
  • Answered
This is just an example.  But when I search, The Hub, for
tNetTask
It brings up all these hits, that do not contain the word tNetTask
Why?
This has happened in the past, so its not exclusively locked to that search...
Two other items, when we search GTAC, why cant there be a filed of XXX entries returned.
So I know if I search and it says 678 items returned, I probably need to refine my criteria.
Photo of Jimmy Sands
Jimmy Sands
  • 432 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,206 Points 20k badge 2x thumb
Hi Jimmy,
Can you let me know where you're searching from?  At the moment, there are several places to search.  The best place right now is the search on our main website: http://www.extremenetworks.com/search/
Searching here on The Hub specifically can yield varying results.  The search above includes filters to narrow down your query to the site and we're finding it often does a much better job.  Google seems to do a good job of finding items on The Hub and on our various web properties.  I think myself and others on my team can help answer your questions, I'd just like to make sure we all understand the issue.
-Drew
Jimmy Sands
Ity bity details I left out.....
I am using a search engine developed and designed by a Taiwanese based produce company ; it uses proprietary code based solely on Lotus Notes.  The support dept reps also double as fish factory workers during their down time. Maybe.   Where am I searching from?  Not sure if I understand...
For the tNetTask search I used The Hub search utility, returned hundreds of results with only the first two or three actually containing that phrase,  The GTAC return only 2 results.
On a different topic, when I do search GTAC (using the search engine https://gtacknowledge.extremenetworks.com/) it never shows how many hits total are being returned.  So if I search for a phrase, and if it returns 1,450 hits....I know I need to refine/drill down my search criteria.  But it never shows the total hits being returned.  I might have 11 hits or 1100....just have to keep clicking Next next next....just my own feelings on the matter
Thank you for that link, the one seems to be the most help.
ty
Photo of Thomas, Ken
Thomas, Ken, Alum
  • 4,368 Points 4k badge 2x thumb
Hi Jimmy, Like Drew was saying our best search is from the corporate site. http://www.extremenetworks.com/search/#q=tNetTask&t=Knowledge&sort=relevancy you can find this search in the top of most of the pages on the extremenetworks.com site. I think you will really like it. It is way better than the GTAC KB search you mentioned using above. It has much better filtering and it has one of the main things you mentioned - a count of records returned, per each tab/source. The All tab should give you the total. Right now there are 2 KB results that include tNetTask and 6 total, from what we call the public search.
If you happen to be a silver level or above partner, our new portal which is still in beta release has an even better technical focused search. We hope in the near future it will be ready for release to all our users, but it is still in beta release right now.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
Even if I use that search portal the articles don't include the string that I've used in the search...
http://www.extremenetworks.com/search/#q=eos%20mac%20authentication%20configuration&t=Knowledge&...
Most of the KBs don't include my search string "eos" so why are they listed.
-Ron
Thomas, Ken, Alum
Very good question - the search uses a feature called partial match, it is set to require 50% of your search terms to be in the results, and the minimum words/phrases in the search to make partial match work is set to 3. Your search has 4 words, so it uses partial match. Anything with at least 2 of your words is a result. If anything has all 4 they should show up as a top result, in theory...  There is a software filter for EOS which you can use, then at least you know that the article has been flagged by the author as related to EOS.
updated: Found an odd bug with our search, related to order of search/filtering and the hyperlink isn't working. I will work on getting that fixed... But if you *filter for Knowledge and also for Software = EOS and then enter your search text, you will see about 65 results that are flagged with EOS as the software and match at least half of your search text.
(Edited)
