To use the Privet IP using the public IP assigned directly to Extreme switch
  • Question
  • Updated 2 years ago
  • Answered
Hi, I have "System Type: X440-48t" "version -" used as server farm. I have connected the ISP leased line from ISP switch directly to server farm and assigned a public IP in the switch’s ISP Vlan. Now I am able to reach the ISP gateway which is Cisco switch from X440-48t and I am able to access the switch from outside. Now we don’t have access to the ISP switch for which we are not able to do a static route back to our private network. So is there any possibility to enable NAT in our switch so that I can translate the private IP to public. If NAT cannot be enabled are there any other options?
Photo of Abdul Raheem
Abdul Raheem
  • 458 Points 250 badge 2x thumb
Posted 2 years ago
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,932 Points 1k badge 2x thumb
No, the Summit X440 doesn't support NAT.
You have two choices:
1. You get a public network from your provider which you use for private purposes (not very likely)
2. You buy a SSA Switch - this one can do NAT
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,314 Points 20k badge 2x thumb
3. buy a cheap firewall to do NAT
Abdul Raheem
Hi Andre and Ronald,
Thank you very much you kind and quick reply.
I wanted to know weather NAT can be enabled in our switch which you have confirmed as no.
once again thank you very much for all.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Good stuff!  Welcome to the Hub Abdul.
