Top AP information in Extreme Management (Netsight)
Andre_Brits_Kan
Contributor II
Hi Community
Perhaps someone can shed some light on the following
55d3327779e94c50a6749c1331797dba_RackMultipart20170504-116286-qsn5cy-Capture_inline.jpg
In Netsight on the Wireless Management Page it lists the TOP AP's for a specific Date.
If we look at the Peak Wireless Bandwidth vs the Peak Wired Bandwidth.
Surely if we push 230Mbs in on the wireless we should see the same on the Ethernet side? (or close to it)
If we look at the second AP it is 229 Mbs on wireless vs 261 Kbs on wired....
This does not look right unless I am reading it wrong.
5 REPLIES 5
Andre_Brits_Kan
Contributor II
At both sites we are running 10.31 on the controllers and 7.1 for netsight. That being said i have some ssid's configured as bridge at ap and other to bridge at controller.
Joshua_Puusep
New Contributor III
Ours looks more normal. We are running Netsight 7.0.9.4 with EWC 10.11.05.0005 in a bridged at controller config.
3edf9b7abf844404a6b04e13ac806d5a_RackMultipart20170504-41017-1exx63k-Top_AP_s_inline.png
Andre_Brits_Kan
Contributor II
At another client (Completely different site) I see the same type of reports
855acba6d7b746a1b91dd43b5fb78ea7_RackMultipart20170504-18582-1gkxyli-Capture_inline.jpg
Andre_Brits_Kan
Contributor II
Hi Nick
No these AP's are connected to a LAN and all the SSID's use either B@AP or B@HWC, no mesh is configured
