Top task "tipFdbAgeT" is high on Summit-200 switch
  • Problem
  • Updated 2 years ago
  • Solved
summit-200 switch has recently experienced a cpu spike causing latency through this switch.  When running top I noticed the task "tipFdbAgeT" is running high which I haven't seen this task before.
could someone please explain what this task represents?  I have tried searching online with no avail.
thanks,
Joey
Photo of Joey
Joey
  • 120 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Joey,
I guess that this task is related to iparp table aging process.
I would try clearing the fdb and iparp table and check if the process utilization normalizes.
Photo of Ijaz Chughtai
Ijaz Chughtai, Employee
  • 220 Points 100 badge 2x thumb
Hi Joey,
The task "tipFdbAgeT' refers to IP FDB Aging Timer on Extremeware switches. You can clear the FDB table on Summit-200 to see if the CPU spike clears out which is probably due to software/hardware mismatch.
For these End of Life products, there are not many troubleshooting tools available. So if clearing table does not help, rebooting the switch will be next step which can re-initialize all the processes and might help.
Thanks,
Ijaz
Photo of Joey
Joey
Thank you for the responses, after further troubleshooting it was a FDB issue where a directly connected device was upgraded which corrupted the IP FDB table.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Glad you got it sorted Joey.
Thanks for joining the Hub!
