Traceroute Not going to next Hop
  • Question
  • Updated 4 years ago
I have an extreme switch connected to a cisco router. I have added the following route towards it:-
2.200.2.144/28 10.143.69.94
While tracerouting from the defined subnet, it is not going to the next-hop. Can anyone please help?
Photo of Ayan Ghosh
Ayan Ghosh
  • 80 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,676 Points 10k badge 2x thumb
I'm not sure to understand. Did you mean you traceroute _to_ that network (/28), or _from_ that network?
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
Does ping work of u have problems only
With trace route ?
Check if ipf is enabled
Capture icmp and see what's the ttl value switch is sending
If config is right u might be hitting a known issue with snmp
Photo of Ayan Ghosh
Ayan Ghosh
@Grosjean:- I meant traceroute to that network.
@Parthiban:- IPF is enabled.....Pls help what is the known issue with snmp?
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Ayan where are you doing the traceroute from? the switch or a PC connected to the switch?
If from a PC does the traceroute stop at the Extreme switch?  If from the Extreme switch can you do a trace route out to a different subnet on the other side of the Cisco router?
From the switch can you ping the cisco router that is directly connected?  Remember to add your VR option in the ping so  ping vr vr-d <host IP>
Also can you do a show IPR and show VLAN and paste the output?
Thanks
P
