Translating Matrix N-series Trap vs CLI Port Numbering
  • Article
  • Updated 5 years ago
Article ID: 5567
Products
DFE
Protocols/Features
SNMP
Traps
Mibs
Netflow
Goals
Translate trap vs cli port numbering
Cause
When an SNMP trap is received from a N-Series DFE system, port references do not directly reconcile to the ifIndex numbering scheme as seen in the cli or in Interface Description mib 'ifDescr=1.3.6.1.2.1.2.2.1.2'.
Solution
To translate between the two numbering methods, query mib 'dot1dBasePortIfIndex=1.3.6.1.2.1.17.1.4.1.2'.
In the sample result shown below, the 'Instance' column contains the 'dot1dBasePort=1.3.6.1.2.1.17.1.4.1.1' (trap) numbering, while the 'Value' column contains the corresponding 'ifIndex=1.3.6.1.2.1.2.2.1.1' numbering which may be further translated to logical port instances as explained in 5456
   Object               Instance  Type     Value
dot1dBasePortIfIndex 1 INTEGER 1
dot1dBasePortIfIndex 34 INTEGER 15501
dot1dBasePortIfIndex 64 INTEGER 11001
dot1dBasePortIfIndex 65 INTEGER 11002
dot1dBasePortIfIndex 66 INTEGER 11003
dot1dBasePortIfIndex 111 INTEGER 11048
dot1dBasePortIfIndex 112 INTEGER 12001
dot1dBasePortIfIndex 117 INTEGER 12006
dot1dBasePortIfIndex 194 INTEGER 25501
dot1dBasePortIfIndex 320 INTEGER 22001
dot1dBasePortIfIndex 321 INTEGER 22002
dot1dBasePortIfIndex 322 INTEGER 22003
dot1dBasePortIfIndex 331 INTEGER 22012
dot1dBasePortIfIndex 1792 INTEGER 1005001
dot1dBasePortIfIndex 1793 INTEGER 1005002
dot1dBasePortIfIndex 1794 INTEGER 1005003
dot1dBasePortIfIndex 1839 INTEGER 1005048
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
