AP3915i mounting option
  • 2
  • Question
  • Updated 3 months ago
  • Answered
  • (Edited)
Why is the logo upside down if mounted on the wall with the default option.
Marketing 101 = brand recognition
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Posted 3 months ago
  • 2
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
You're holding it wrong.
Kidding. I'll see if we can get the product guys to respond.
Photo of James A
James A, Embassador
  • 6,542 Points 5k badge 2x thumb
¿ƃuoɹʍ ʇı ƃuıpʃoɥ ǝɹ,no⅄
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,566 Points 5k badge 2x thumb
Please consult the manual for the correct viewing angle of this device ...
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,582 Points 10k badge 2x thumb
1 d0n'7 und3r574nd 7h3 155u3. h0w w0uld y0u 3xp3c7 7h3 3x7r3m3 l060 70 b3?
Another Q to the "product guys"...
AP3715i and WiNG AP7632 use the same hardware.
Why does the WiNG AP include a mounting bracket but it's not included with the 3715i  - they cost the same.
This basic mounting bracket would allow to install the AP the correct way.... instead we must buy the optional mounting bracket for extra $$$.
Photo of Aguilar, William
Aguilar, William, Employee
  • 2,664 Points 2k badge 2x thumb
Hi Ron,
Most enterprise installations will use either the optional wall mounting bracket or the tool-less drop ceiling bracket which will result in the logo being positioned correctly.  We discourage the use of the screw holes on the back but it is there from a legacy perspective.  To be honest and transparent, the logo direction was an oversight that I didn't pick up until late in the cycle and changing it would have impacted the release schedule since it would change tooling and require recertification for electrical/safety.  Changing the direction of the logo (and not the holes pattern) would have lead folks to install with the E/N ports down requiring the cable to wrap around the AP when the cable comes from the ceiling.  Because we expect most installations to use the mounting brackets, based on feedback from the field on other programs, I made the call to let it go as is.
To your second comment about why the AP3915 doesn't ship with any bracket and the AP7632 does - the decision was based on the fact that most AP3915 installations will be for drop ceilings due to the smoke detector footprint while most AP7632 installations will likely be replacing previous WiNG legacy installs in Retail, T&L, etc. that are using legacy brackets.  Shipping the metal bracket with the AP3915 will likely result in many customers throwing them away and using the drop ceiling bracket that supports a multitude of drop ceiling rail types and sizes.  However, the metal bracket can be used on 9/16" flush drop ceilings and as result of some of the early feedback from customers we are considering adding the same bracket to the AP3915 for future hardware revs.  But in the meantime you will need to order one of the optional brackets that meet your customer's needs.
Thanks,
Will
