Trouble Creating port mirror on Extreme Summit x440 Switch
  • Question
  • Updated 3 years ago
  • Answered
I'm having trouble with the CLI on my switch.  When I try to configure my port mirror I receive the error invalid slot number detected at marker.  I know the port I need to mirror is on slot1 of the stack but anyway I input the slot number it gives me the same error.  Any help is greatly appreciated.  Thank you.
Desmond
Command I'm trying: configure mirror DES add port 25 slot-1 ingress-and-egress
Photo of Desmond Gonzales
Desmond Gonzales
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 6,214 Points 5k badge 2x thumb
configure mirror add port 1:24??
Desmond Gonzales
Hello, I'll give it a try.  Does 1 represent destination or port to be mirrored?
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
As David mentioned you want to use the command below:
configure mirror DES add port 1:25 ingress-and-egress
The slot number goes in before the colon of each individual port when stacking is used.
Desmond Gonzales
Thanks David.  That did the trick.  I really appreciate the assistance!
