Trouble with bidirectional ping
  • Problem
  • Updated 3 years ago
  • In Progress
Hello everyone,
I have a problem with my switch configuration, the topology is the next:
In the ports 1-4 are my servers of videoconferencing and the ports 45-46 are the gateways to two junipers.
In the ports 25-28 are two Cisco VCS’s and a Dell Server, ports 47-48 are the gateways to the local core.
The configuration is the following:
show conf
# Module devmgr configuration.
configure snmp sysName "Infotec"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-64
configure vr VR-Default add ports 1-64
configure vlan default delete ports 1-4, 25-28, 30, 45-48
create vlan "Acano"
configure vlan Acano tag 61
create vlan "Local"
configure vlan Local tag 421
enable sharing 47 grouping 47-48 algorithm address-based L2 lacp
configure vlan Acano add ports 1-4, 45-46 untagged
configure vlan Default add ports 5-24, 29, 31-44, 49-64 untagged
configure vlan Local add ports 25-28, 30, 47 untagged
configure vlan Mgmt ipaddress 192.168.127.5 255.255.255.0
configure vlan Local ipaddress 192.168.127.13 255.255.255.0
enable ipforwarding vlan Local
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 192.168.127.254
# Module mcmgr configuration.
# Module aaa configuration.
# Module acl configuration.
configure access-list zone SYSTEM application NetLogin application-priority 4
configure access-list zone SECURITY application GenericXml application-priority 2
# Module bfd configuration.
# Module ces configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
disable edp ports 1
disable edp ports 2
disable edp ports 3
disable edp ports 4
disable edp ports 45
disable edp ports 46
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lacp configuration.
# Module lldp configuration.
enable lldp ports 1
enable lldp ports 2
enable lldp ports 3
enable lldp ports 4
enable lldp ports 45
enable lldp ports 46
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
# Module ospf configuration.
configure ospf routerid 207.249.126.17
create ospf area 0.0.0.1
create ospf area 1.0.0.0
configure ospf vlan Local priority 0
# Module ospfv3 configuration.
# Module pim configuration.
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
# Module stp configuration.
configure mstp region 00049697b974
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
enable stpd s0 auto-bind vlan Default
# Module synce configuration.
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
enable web http
# Module vmt configuration.
# Module vrrp configuration.
# Module vsm configuration.
My question is that my switch can reach everyone and vice versa, but the servers of videoconferencing can’t reach no one of the switch. I already try with LLDP, LACP, even EDP, and no luck, is there some other protocol to try or what can I do? I really appreciate all your help.
Photo of jesus mazon
jesus mazon
  • 70 Points
  • confused
Posted 3 years ago
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
you have 2 vlans: Acano and Local, but ip address and ipforwaring are set only for vlan Local.
Is it correct config ? Do you have routing to those vlans somewhere else ? ( local core or gateways )
Jarek
Photo of Frank
Frank
  • 3,662 Points 3k badge 2x thumb
Another thing that I've noticed is that your network management vlan is in the same network as vlan "local" - I don't know what can of worms that opens. (And what Jarek said, of course :) )
