Trouble with WLC and Zebra/Moto MC3190
  • Problem
  • Updated 2 years ago
  • Not a Problem
hello,
I have  WLCv2110 and AP38xx and some Zebra/Motorola MC3190 scanners.
And I have follow trouble -
MC's lost connection sometimes and I have to reboot AP or MC to the scanner again work.
ping MC looks like strange
64 bytes from 10.121.12.213: icmp_seq=7 ttl=125 time=357 ms
64 bytes from 10.121.12.213: icmp_seq=8 ttl=125 time=31.9 ms
64 bytes from 10.121.12.213: icmp_seq=9 ttl=125 time=54.7 ms
64 bytes from 10.121.12.213: icmp_seq=10 ttl=125 time=77.0 ms
64 bytes from 10.121.12.213: icmp_seq=11 ttl=125 time=99.7 ms
64 bytes from 10.121.12.213: icmp_seq=12 ttl=125 time=19.3 ms
64 bytes from 10.121.12.213: icmp_seq=13 ttl=125 time=41.9 ms
64 bytes from 10.121.12.213: icmp_seq=14 ttl=125 time=64.5 ms
64 bytes from 10.121.12.213: icmp_seq=15 ttl=125 time=87.0 ms
64 bytes from 10.121.12.213: icmp_seq=16 ttl=125 time=109 ms
64 bytes from 10.121.12.213: icmp_seq=17 ttl=125 time=131 ms
64 bytes from 10.121.12.213: icmp_seq=18 ttl=125 time=153 ms
64 bytes from 10.121.12.213: icmp_seq=19 ttl=125 time=177 ms
64 bytes from 10.121.12.213: icmp_seq=20 ttl=125 time=200 ms
64 bytes from 10.121.12.213: icmp_seq=21 ttl=125 time=222 ms
64 bytes from 10.121.12.213: icmp_seq=22 ttl=125 time=244 ms
64 bytes from 10.121.12.213: icmp_seq=23 ttl=125 time=267 ms
64 bytes from 10.121.12.213: icmp_seq=24 ttl=125 time=290 ms
64 bytes from 10.121.12.213: icmp_seq=25 ttl=125 time=313 ms
64 bytes from 10.121.12.213: icmp_seq=26 ttl=125 time=335 ms
64 bytes from 10.121.12.213: icmp_seq=27 ttl=125 time=357 ms
64 bytes from 10.121.12.213: icmp_seq=28 ttl=125 time=380 ms
64 bytes from 10.121.12.213: icmp_seq=29 ttl=125 time=402 ms
64 bytes from 10.121.12.213: icmp_seq=30 ttl=125 time=16.6 ms
64 bytes from 10.121.12.213: icmp_seq=31 ttl=125 time=38.7 ms
Photo of Alexander
Alexander
  • 140 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
Do you have a rekey interval set on your WLAN privacy? If you do not, the session can become stale until it reconnects after the reboot
Photo of Alexander
Alexander
yes, rekey interval set off. I forget about it(
Joseph Burnsworth
Did you turn it on? Did it help you? Let us know when you can :)
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,578 Points 5k badge 2x thumb
Hello Alexander
If you are still experiencing issues I would suggest opening a case with GTAC so we can look through the logs etc.
-Gareth
