Trunking port
  • Question
  • Updated 5 years ago
  • Answered
How do I create a trunk port on a extreme switch (X440)?
The goal is to allow a PC to connect to the native vlan via a Cisco IP Phone while all VoIP traffic connects to the voice vlan. It is my experience that the IP phone and switch port needs to be set to trunking or auto negotiate trunking in order to separate the traffic and achieve separation of data from voice.
I have all of my experience in Cisco IOS, and familiar with this syntax.
Assign port to vlan
hostname(config)# switch port access vlan [tag name]
create trunk port
hostname(config)# switchport mode trunk
Photo of Theo
Theo
  • 282 Points 250 badge 2x thumb
Posted 5 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
Hello Theo
The way we create "trunk ports" is simply by adding the ports to the VLANs as tagged ports.
For example if we have two VLANs data and Voice that need to be on the same port we would do the following
Create vlan data
create vlan voice
config voice tag 100
config data add port 1
config voice add port 1 tagged
If we had more VLANs we would just continue to add the port as a tagged port to each VLAN.
Hope that helps
Thanks
P
