Trying to upgrade a x440 using the bootRom
  • Question
  • Updated 3 years ago
  • Answered
Trying to upgrade the image from 15.3.1 to 16.1.1.4 through the bootRom but I keep getting a message saying that this is not a recovery image or it might be corrupted. I have tried different xos but with thw same results.
Photo of Carlos Maldonado
Carlos Maldonado
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 38,612 Points 20k badge 2x thumb
Hi Carlos,
What is the command and filename you're using in the BootROM?  I'm also curious to know the reason you're using the bootrom method and not upgrading from within EXOS?
Carlos Maldonado
I'm using first the command configip address 192.168.1.100/24 gateway 192.168.1.10 and then download image 192,168,1,10 summitX-16.1.1.4.xos
I'm new with the extreme so if there is a better way let me know.
Photo of Drew C.
Welcome to Extreme (and The Hub)!
Take a look at this article:  How to Obtain and Upgrade EXOS  It will help explain the normal way to upgrade.
The BootROM method will erase all config on the switch, which you probably don't want to happen.
(Edited)
Carlos Maldonado
Thanks, got it working
