Two APs of 100 don't work - strange LEDs blinking
  • Problem
  • Updated 3 years ago
  • Solved
Hello, everybody!
I have two 3825i APs, which don't work.
There is constant LED blinking on the APs like blinking at the switch (X430-8p) side. There are three more same APs at this switch and they work as expected. I have recorded a video. Please, see the link below. All other ~100 APs at other switches work well.
https://cloud.mail.ru/public/Gi7w/ZQkBgE5mn
On the controller I have a log message:
05/17/16 16:29:08 Minor Config Manager Config Manager has failed to process a request. Config Manager is still running, and system functionality is not impaired. Error Details: Configuration has been resent the maximum number times, but no acknowledge has been received. Releasing AP[15244979085J0000]
But I am not sure that this message is related to those fault APs.
Please, help me to bring these APs to work.
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 3 years ago
Photo of FES
FES
  • 1,360 Points 1k badge 2x thumb
You can set poe off at the port and turn on poe again. If the problem persists try to connecto to de ap (telnet or ssh) and type the 'cset factory' to reset the ap.
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
Telnet is not available on 38xx AP's , so ssh is a good suggestion to factory reset. Also there is a small pin you can hold for 20 sec at the back of the AP which will do also the factory reset.
What discovery method do you use? DNS? DHCP? Or same-subnet multicast? If mutlicast and the switch port AP connected to has igmp snooping enabled it will not be able to find the controller.
Ilya Semenov
Discovery method is DNS. All other APs at this switch work well. The port configuration is same. Ok, I'll try to reset them.
Thank you.
Ilya Semenov
Hello,
I have already restarted the APs this way. No result. They don't get an IP address. You mean that only way is to reset them using  'cset factory' command over console?
Thanks, Ilya
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,994 Points 5k badge 2x thumb
Ilya
If the AP doesn't get an IP address, do you see it request one on your DHCP server?   Maybe the lease database is full?
Perhaps a port mirror on the switch to a sniffer might help see if anything is sent/received on that port from the AP?
Does the switch learn the MAC of the AP on its port and in the correct vlan?
Could you swap a working AP cable/port to the non working one see if this changes anything?
Beyond that I would contact the GTAC for further help.
-Gareth
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,458 Points 50k badge 2x thumb
My advice is to get the AP from the ceiling for troubleshooting.
That would make it a lot easier as it looks like you don't even know the serialnumber of the AP.
Without the SN you can't check the controller logs for errors.
Connect to the console and call the GTAC for a remote session - that will save you some time if you are not familiar with the product.
The switch LEDs show only connected devices on 2,5,6 - on which ports are this 2 APs that don't work.
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-the-LED-statuses-of-the-Summit-x440-...
Scroll down for LED status of PoE switch.
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,820 Points 5k badge 2x thumb
I'm with Ron that you should pull them down off the ceiling for troubleshooting. PoE can be pretty sensitive sometimes. Try plugging one directly into the switch using a short cable. If it comes up fine, you might have a loose wire or a run of cable that is too long.
What else do you have plugged into the switch that is using PoE? If you have security cameras, phones, etc, you might be depleting the power.
Ilya Semenov
Steve, it's not depleting the power. There are only 5 3825i APs in the switch and three of them work. The minimum power consupmtion of 3825i is about 4.9W accordinly to sh inline-power status. There is no load at the moment because of lack of users. I have conducted an expirement checking how much AP can X430-8p support - so it supports 8 3825i simultaneously (with minimum load certainly).
Today I'll force the adjusters to get both faulty APs from ceiling for checking.
Thanks to all!
