Two X440 stacked random access to management
  • Problem
  • Updated 11 months ago
  • Solved
Hello
I'm quite new to Extreme and have yet some limited knowledge about XOS.
But the story is that i have replaced our core router (X440-24t) with two "new" X440-24t in stack.
Firmware version 16.2.2.4 as Extreme recommends for the X440.
I have copied most of the configuration from the old one.
Management port connected with cable to switch port 1:1 with untagged VLAN401
I did run the stack config-guide-thingie and it went wonderful, and at the lab where i set them up it worked perfectly.
I have it set them to act as router for 3 ip ranges.
But when i moved the switches to the server room i began to get random access to the mgmt interface. Tho all traffic to and from configured VLANs are working perfect.
After a lot of troubleshooting i noticed that i can access the mgmt-cli via our external IP's that i have configured in the switch, now, i thought this was not possible after reading a lot on vr-mgmt access.
I have also random access for outgoing traffic from vr-mgmt to any, basically, for ex. ping google it works sometime but most of the time it does not.
But when i access SSH thru our external IP i get no errors or disconnect from cli as i get when connected thru the internal IP i have setup on the mgmt vlan.
I can access the mgmt-cli thru any of the VLAN105X ip addresses.
Now, what have i done wrong?
Config:
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-24,2:1-24
configure vr VR-Default add ports 1:1-24,2:1-24
configure vlan default delete ports 1:1-24,2:1-24
enable jumbo-frame ports all
configure vman ethertype 0x8100 secondary
configure iproute add default 172.16.254.1 vr VR-Mgmt
configure iproute add default xx.xxx.88.93
configure vlan Mgmt ipaddress 172.16.254.254 255.255.255.0 configure vlan WAN ipaddress xx.xxx.88.94 255.255.255.252 enable ipforwarding vlan WAN configure vlan VLAN1052 ipaddress xx.xxx.60.193 255.255.255.224 enable ipforwarding vlan VLAN1052 configure vlan VLAN1053 ipaddress xxx.xxx.115.129 255.255.255.240 enable ipforwarding vlan VLAN1053 configure vlan VLAN1054 ipaddress xxx.xxx.115.145 255.255.255.240 enable ipforwarding vlan VLAN1054 configure vlan VLAN1055 ipaddress xxx.xxx.115.161 255.255.255.224 enable ipforwarding vlan VLAN1055
I also noticed that when im doing an arping from an linux machine i get this
# arping -D -I ens32 -c 6 172.16.254.254
ARPING 172.16.254.254 from 0.0.0.0 ens32
Unicast reply from 172.16.254.254 [00:04:96:98:04:B6]  0.904ms
Sent 1 probes (1 broadcast(s))
Received 1 response(s)
# arping -I ens32 -c 2 172.16.254.254
ARPING 172.16.254.254 from 172.16.254.41 ens32
Unicast reply from 172.16.254.254 [02:04:96:6D:59:9B]  0.916ms
Sent 2 probes (1 broadcast(s))
and on the switch i get this from iparp
# sh iparp vr "VR-Mgmt"
VR            Destination      Mac                Age  Static  VLAN          VID   Port
VR-Mgmt       172.16.254.41    00:50:56:b6:ac:1e    2      NO  Mgmt          4095
Dynamic Entries  :           6             Static Entries            :          0
Pending Entries  :           1
In Request       :       15389             In Response               :       1671
Out Request      :       30438             Out Response              :       3924
Failed Requests  :        4656
Proxy Answered   :        3913
Rx Error         :           0             Dup IP Addr               :  172.16.254.254
Rejected Count   :         307             Rejected IP               :   172.16.254.41
Rejected Port    :                         Rejected I/F              :
Max ARP entries  :        4096             Max ARP pending entries   :        256
ARP address check:    Enabled              ARP refresh               :    Enabled
Timeout          :          20 minutes     ARP Sender-Mac Learning   :   Disabled
Locktime         :        1000 milliseconds
Retransmit Time  :        1000 milliseconds
Reachable Time   :      900000 milliseconds (Auto)
Fast Convergence :         Off
I'm going mad soon :)
Photo of Magnus Isaksson
Magnus Isaksson
  • 172 Points 100 badge 2x thumb
  • frustrated
Posted 11 months ago
Photo of Drew C.
Drew C., Community Manager
  • 38,472 Points 20k badge 2x thumb
In short, don't do it this way :)
The mgmt port is for true out-of-band management and shouldn't be connected back into the same switch.
Take a look at the discussion in this thread: https://community.extremenetworks.com/extreme/topics/recommendation-for-configuration-of-management-...
(Edited)
Magnus Isaksson
Thank you
If i understand this correctly, i just need to set an IP on VLAN401 (it our mgmt vlan) and then i can manage the switch without connection to the management port?
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
The mgmt VLAN in the switch is dedicated for the management port. It is separate to the rest of the ports and they will not mix. Any of the created VLAN IPs can be used to manage the switch.
Patrick Voss, Alum
Hello Magnus,
At first glance it looks like a duplicate IP. The arping output is showing 00:04:96:98:04:B6 and 02:04:96:6D:59:9B. These are both Extreme Switches. The one starting with 02 is a stack mac address. Can you confirm what the other switch is? It may be one of the nodes in the stack. You should be able to find this with the "show stacking detail" output if you want to paste it in here.
Magnus Isaksson
Hi
both mac belong to stack-1
# sh stacking detail
Stacking Node 00:04:96:98:04:b6 information:
   Current:
      Stacking                  : Enabled
      Role                      : Master
      Priority                  : Automatic
      Slot number               : 1
      Stack state               : Active
      Master capable?           : Yes
      Stacking protocol         : Enhanced
      License level restriction : <none>
      In active topology?       : Yes
      Factory MAC address       : 00:04:96:98:04:b6
      Stack MAC address         : 02:04:96:6d:59:9b
      Alternate IP address      : <none>
      Alternate gateway         : <none>
      Stack Port 1:
         State                  : Link down
         Blocked?               : No
         Control path active?   : No
      Stack Port 2:
         State                  : Operational
         Blocked?               : No
         Control path active?   : Yes
   Configured:
      Stacking                  : Enabled
      Slot number               : 1
Patrick Voss, Alum
Can you send us a "show vlan" output?
Magnus Isaksson
Yes, mgmt port is connected with a cable to port 1:1 on switch 1, but i did not do that to switch 2
Patrick Voss, Alum
I think that might be your problem. The MGMT port should be used for out of band management which means it needs to be connected to another switch. Considering the MAC addresses are shared looping the port into itself can cause come confusion. Disconnect that port and try to access one of the user created IP addresses and see if your issue goes away.
Magnus Isaksson
I did as you suggested, added an IP on VLAN401 and disabled port 1:1
Seems to work great now :)
I just did as they had done on the old switch, tho there was no stacking involved there.
But the access to mgmt from all the IP:s configured on the switch is to be expected?
Is there a way to limit that except thru ACL?
And thanks for the help! was about to get mad there for a moment :)
Patrick Voss, Alum
Yes as long as you can reach the IP you can telnet or SSH to it. There is a way to limit who can access the switch using an access profile for SSH:
https://gtacknowledge.extremenetworks.com/articles/Q_A/SSH-Access-Profile
Magnus Isaksson
Thank you so much for your help!
