UDLD ELSM
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jul 26 2013 9:12PM
I have other vendor switch and extremenetworks switch, but I want use fiber link these switches. Can I use UDLD and ELSM
UDLD
(from Hsu_LiPing)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Aug 1 2013 10:05AM
If You want to connect cisco and extreme networks with link status check so unfortunately UDLD and ELSM is not compatible. You should disable UDLD on cisco and ELSM on extreme on uplinks, otherwise for ex. if you have four switches in ring (E2 C1C2E1E2C1) and C1 loses connection to E2, UDLD will think that link is broken and will disable port on C2E1, so You loses connection between cisco and rest of extreme switches.
(from karpiu)
