UDP port for syslog in 16.x EXOS
  • Question
  • Updated 1 year ago
  • Answered
Hello, everyone!
I have 460-G2 switch with 16.2 EXOS.
The problem is I can't configure syslog, using this article:
Everything works fine in 15x EXOS, but not in 16.x. In 15x using the settings from article mentioned above I get all required info in syslog: ports' status and almost all the events.
In 16x I don't receive anything. The syslog server is the same (kiwi).
However, after "enable cli-config-logging" command I get copies of commands entered to syslog.
How can I fix the issue?
The syslog settings in X460-G2 (EXOS 16.2) configuration are:
configure syslog add vr VR-Default local0enable log target syslog vr VR-Default local0
configure log target syslog vr VR-Default local0 filter DefaultFilter severity Info
configure log target syslog vr VR-Default local0 match Any
configure log target syslog vr VR-Default local0 format timestamp seconds date Mmm-dd event-name none priority host-name tag-name
The first thing I want to get is mac-locking events!
Could you please help me?
Many thanks in advance,
Photo of Ilya Semenov
Ilya Semenov
  • 3,622 Points 3k badge 2x thumb
Posted 1 year ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,280 Points 20k badge 2x thumb
Could you please post the output for " show log configuration target syslog"
Ilya Semenov
Hello, Donald!
Here is the output:
X460G2-24p-10G4.2 # show log configuration target syslogLog Target      : syslog; (vr VR-Default), local0
    Enabled     : yes
    Filter Name : DefaultFilter
    Match regex : Any
    Severity    : Info (through Critical)
    Format      : PRI Mmm DD HH:MM:SS HOSTNAME TAG:
Thank you!
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 964 Points 500 badge 2x thumb
Hi Ilya,
Please check the information on mac-locking available in the below link,
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
HI Ilya,
Considering that the log messages related to the CLI configuration are sent to the syslog server, I am assuming that the syslog configuration is working fine.
I believe the filter used "default filter" is optimized. To confirm this, can you please share the complete output of the command, "show configuration ems"
looking forward to your response.
