Unable to add RBT-4102-EU to Enterasys Wireless Controller V2110 (0.8.21.02.0060)
  • Problem
  • Updated 3 years ago
  • Solved
Dear all
Any advise?
I'm trying to extend my wireless area coverage with RBT-4102-EU, I have 2 APs 3705i that are currently connected to our EWC-1 v2110, I went to the webview of EWC and key in the serial number and name but it keep prompting me to enter a valid serial number and wireless ap name.
 I had followed the steps to convert as shown below:
https://community.extremenetworks.com/extreme/topics/how_to_convert_an_rbt_4102_access_point_to_work...
Photo of littlefurball
littlefurball
  • 202 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
Is the access point already provisioned on the controller? Look under the AP Tab, Bulk Configuration, Access Approval.
littlefurball
Hi Doug
Thanks for replying, from the Bulk Configuration It's not shown there as approved, it just shows approved for my two AP 3705i. How can I get it provision on the controller?
Is it because It's not detecting my RBT 4102 ap ?
 Thanks
littlefurball
Just wondering, if  I should try the below steps:
1) Download AP4102 (EU) Thin ImageThin image ( is this AP image for controller to download?) from
https://extranet.extremenetworks.com/downloads/Pages/RoamAbout4102.aspx
2) Upload to FTP and then download the image from FTP in the EWC webview.
3) check if controller can detect
Photo of Doug Hyde
It would be the EU conversion firmware found here: https://extranet.extremenetworks.com/downloads/Pages/dms.ashx?download=31346c51-39a5-404c-9506-c7247...
You don't need to load it on the controller, once the access point connects with the controller it will update the access point to the matching code the controller is running.
littlefurball
Thanks Doug
Sorry do you have another link?
littlefurball
Thanks alot Doug Working Now :)
