Unable to connect to XMC 8.1 with Java-concoles
  • Question
  • Updated 1 month ago
  • Answered
Hello, team,
I've done a clean install of XMC, PV and NAC  - everyting version 8.1 - under ESXi. XMC, PV, NAC and client computers are in the same VLAN. There are no firewalls between them. Everything is sinchronyzed with single NTP. All DNS recored were created. I can ping NAC from XMC and vice versa.
I've added to XMC PV and NAC - they both are green.
The problem is I can't connect with Java-consoles to XMC. "Unable to connect to management server". Nothing in XMC's log, the same in NAC's. I've turned it to verbose.
What most likely could be the problem? I hope this is 8.1 version specific issue...
Please, help!
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,462 Points 4k badge 2x thumb
Posted 1 month ago
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,586 Points 5k badge 2x thumb
Is your Java up to date? I seem to remember all my Java consoles failing following an XMC upgrade, and it was an update to my Java that fixed it.
Ilya Semenov
It's 10th Java. The latest.
Photo of James A
James A, Embassador
  • 6,626 Points 5k badge 2x thumb
Try Java 8 or 9 instead? I know with Java 9 it didn't work straight away (can't remember if it was an XMC or Java minor upgrade that fixed it, I was trying it for HiDPI support).
(Edited)
Photo of SH
SH
  • 3,204 Points 3k badge 2x thumb
