Unable to create Guest Portal on EWC running v9.12.02.0006
  • Problem
  • Updated 4 years ago
I'm having trouble when I am configuring Guest Portal on V2110 running 09.12.02.0006.
When I try to enable WLAN Services on Guest Portal, it is shown the message "Captive Portal requires L3 presence. WLAN Service is disable."
I configured the interface L3 in the  topology to the Guest Portal.
Does anyone have any idea what might be missing in the configuration of Guest Portal?
I think this is bug because I saw this same issue in another version.
Thanks in advance,
Edson Moura
Photo of Edson Moura
Edson Moura
  • 472 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Jason
Jason, Employee
  • 3,608 Points 3k badge 2x thumb
Hello Edson,
You are seeing this message because the Non-Auth Role(Policy) for the Guest Portal is set to "Allow" or "Deny".  If you change the Non-Auth Role to be "Contain to VLAN", and set this VLAN to the Guest Portal topology, it should resolve this issue.
Thanks,
Jason
Edson Moura
Hello Jason,
I done like you suggested and this resolved the issue. The question is: Why I have to configure "Contain to Vlan" wherein I can bind WLAN with Topology and bind VNS with WLAN?
Thanks,
Edson Moura
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
But that was fixed in v8.32.07 - was it not ported to v9.12 ?
wns0010553     = Added a GUI enhancement to prevent an administrator from entering a bad ICP non-Auth configuration.
