Unable to create vlan interface
  • Problem
  • Updated 6 months ago
  • Solved
I try to create a new vlan and assing a IP but when add the IP Address to vlan I had a message:
"Could not Create Vlan Interface".
>set vlan create 101
>set vlan name "example"
>router
>>enable
>>>configure
>>>interface vlan 101
>>>"Could not Create Vlan Interface."
Photo of Alan Martinez
Alan Martinez
  • 82 Points 75 badge 2x thumb
Posted 6 months ago
Photo of Tooley, Akiko
Tooley, Akiko, Employee
  • 600 Points 500 badge 2x thumb
Photo of Careno, Ryan
Careno, Ryan, Employee
  • 1,092 Points 1k badge 2x thumb
What is the switch model?  You may be hitting the maximum number of routed interfaces, so check the release notes for your switch model and firmware version.  Our C3/G3/B5  switches have a maximum of 24 routed interfaces, where our C5 has 48 maximum routed interfaces.
Alan Martinez
Thanks Ryan for your answer.
It is correct, reviewing the configuration I have 24 virtual interfaces.
The model of the switch is B5K125-48P2
I will look for information about it to present to my superiors, thank you very much for your help.
Anytime, not a problem.
To follow up, I have created the following Knowledge Article for this error:
https://gtacknowledge.extremenetworks.com/articles/Solution/B-C-G-Series-attempt-to-create-L3-Interf...
