Unable to Del IPmc sender entry
  • Question
  • Updated 3 years ago
  • Answered
after changing slot 2 in stack i can see below error . please let me know how to stop these error.
can i use disable igmp snooping on perticular vlan ...
Slot-1 VKIBCSW02.1 > show log severity error
01/12/2016 19:17:13.56 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,3004 IPMC 0 was not added to all switching resources rc -21
01/12/2016 19:17:13.53 <Erro:Kern.IPv4Mc.Error> Slot-2: Unable to Del IPmc sender entry s,G,v=0,e0000012,3004 IPMC 0 flags 2 unit 1, Entry not found
01/12/2016 19:17:07.22 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,103 IPMC 2 was not added to all switching resources rc -21
01/12/2016 19:17:07.00 <Erro:Kern.IPv4Mc.Error> Slot-2: Unable to Del IPmc sender entry s,G,v=0,e0000012,103 IPMC 2 flags 2 unit 1, Entry not found
01/12/2016 19:17:06.31 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,109 IPMC 1 was not added to all switching resources rc -21
01/12/2016 19:17:06.02 <Erro:Kern.IPv4Mc.Error> Slot-2: Unable to Del IPmc sender entry s,G,v=0,e0000012,109 IPMC 1 flags 2 unit 1, Entry not found
01/12/2016 19:15:48.06 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,3004 IPMC 0 was not added to all switching resources rc -21
01/12/2016 19:15:48.00 <Erro:Kern.IPv4Mc.Error> Slot-2: Unable to Del IPmc sender entry s,G,v=0,e0000012,3004 IPMC 0 flags 2 unit 1, Entry not found
01/12/2016 19:15:41.12 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,103 IPMC 2 was not added to all switching resources rc -21
01/12/2016 19:15:41.09 <Erro:Kern.IPv4Mc.Error> Slot-2: Unable to Del IPmc sender entry s,G,v=0,e0000012,103 IPMC 2 flags 2 unit 1, Entry not found
01/12/2016 19:15:39.60 <Erro:Kern.IPv4Mc.Error> Slot-2: IPmc sender entry s,G,v=0,e0000012,109 IPMC 1 was not added to all switching resources rc -21
Version & stack info given below
Slot-1 VKIBCSW02.2 > show stacking
Stack Topology is a Ring
Active Topology is a Ring
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:37:11:b5  1     Active       Master   CA-
 00:04:96:35:16:2a  2     Active       Backup   CA-
* - Indicates this node
Flags:  (C) Candidate for this active topology, (A) Active Node
        (O) node may be in Other active topology
Slot-1 VKIBCSW02.3 > show version
Slot-1      : 800302-00-01 1007G-80144 Rev 1.0 BootROM: 1.0.3.5    IMG: 15.3.1.4
Slot-2      : 800163-00-11 0822G-80687 Rev 11.0 BootROM: 1.0.5.7    IMG: 15.3.1.4
Slot-3      :
Slot-4      :
Slot-5      :
Slot-6      :
Slot-7      :
Slot-8      :
XGM2-2sf-2  : 800254-00-03 1045G-00282 Rev 3.0
Image   : ExtremeXOS version 15.3.1.4 v1531b4-patch1-33 by release-manager
          on Thu Mar 20 12:43:39 EDT 2014
BootROM : 1.0.3.5
Photo of Narender kumar
Narender kumar
  • 430 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
Hi Narender, here's an article from our Knowledgebase that could be the issue you're experiencing: https://gtacknowledge.extremenetworks.com/articles/Solution/Unable-to-Add-L2
A firmware upgrade would be a good place to start.  For the X450 stack you have, EXOS 15.3.5.2-patch1-8
(Edited)
