Unable to enable VIM slot for stacking
  • Problem
  • Updated 5 months ago
  • Solved
As one can imagine, I'm new to Extreme and EXOS.   I've inherited some X460-G2 10Gbit switches and they have the Summit X460-G2 VIM-2x cards installed in the VIM slot.   They aren't in use at the minute and I wanted to be able to enable these for stacking / MLAG.
I've enabled stacking and rebooted the switch, but when I go
show stacking-support
It only shows the SFP+ ports 51 and 52 (which are the front fiber ports).
show switch does show the VIM-2x card.
Any suggestions?
EXOS version:  21.1.4.4
Photo of Sean Scarfo
Sean Scarfo
  • 236 Points 100 badge 2x thumb
  • frustrated
Posted 5 months ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,254 Points 10k badge 2x thumb
Hi Sean,
On the X460-G2-10G, the front 10G ports are used for alternate stacking (to allow alternate stacking without requiring the VIM-2x).
On the X460-G2-1G (without built-in 10G ports), the VIM-2x is needed for alternate stacking.
Unfortunately, there isn't a way to use the VIM-2x ports for alternate stacking on the 10G version of the X460-G2.
Sean Scarfo
ok, so can I use the VIM-2x ports for anything on these switches?
(Edited)
Yes, you can use the VIM-2x as two 10 gigabit SFP+ ethernet ports. They are ports 53 and 54.
(Edited)
Sean Scarfo
nm, they show up now.  go figure.  Thank you!
Sean Scarfo
