Unable to upgrade firmware in Management Center on a single switch
Jesse_Ohlsson
New Contributor II
I've added three X440 switches to my new installation of Management Center. I am in full control of them with SNMP and CLI credentials. Management Center successfully backs up their configurations.
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-120239-14vfng8-3_switches_inline.jpg
When I select one of the switches to upgrade firmware (I know, they are already on the latest version), I get the normal dialog window:
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-106476-l6c1r1-Eagan_firmware_inline.jpg
...except, if I try to do that with the last switch I added, here called Silverdale, WA:
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-106476-1mn11il-Silverdale_firmware_inline.jpg
No difference exists between this and the other two switches. How can I manage the firmware on this switch using Management Center?
9 REPLIES 9
Jesse_Ohlsson
New Contributor II
Sadly, the solution was to delete the device from Management Center, and then add it again. I tried rediscovering it, to no avail.
But, after I added it again, the firmware upgrade process starts normally.
Jesse_Ohlsson
New Contributor II
Frank,
I have to refer you back to this image which I posted above:
e284ecda6506471c8dd444bdba7161dc_RackMultipart20160729-55014-t5t8yd-Silverdale_firmware_inline.jpg
On that one switch only, I can't get as far as the screenshot you posted.
Jesse_Ohlsson
New Contributor II
Yes, I'll have to find where that's done in Management Center.
Hit the set Config button next to assigned image for the web view of that screen.
fc450976188d46e3970248575f2d0319_RackMultipart20160729-7474-b87rrc-inventorymanagerdevice_inline.png
