Unable to use WinSCP to connect to XOS Switches anymore
  • 2
  • Problem
  • Updated 3 weeks ago
Anyone else having trouble using WinSCP to connect to XOS switches?
Unfortunately I haven't had to connect for some time, so I cant pinpoint when it stopped working.
Windows 10 running WinSCP 5.13.4 (Build 8731)
- checked Windows firewall
- turned off "Optimize the connection buffer size"
- returns "Host is not communicating for more than xx seconds. Still waiting..."
Connecting to:
System Type:      X670G2-48x-4q
ExtremeXOS version 21.1.5.2
SSH Secure-Mode    : On
- No errors displayed in the log file
- Can SSH in from same PC with no troubles
Hoping someone else has already stumbled across this.
Regards,
Photo of Rowan Sakul
Rowan Sakul
  • 364 Points 250 badge 2x thumb
Posted 1 month ago
  • 2
Rowan Sakul
Grabbed this out of the WinSCP log file, looks like there's an error at the CLI prompt causing the issue.
. 2018-09-18 14:40:51.229 Access granted
. 2018-09-18 14:40:51.229 Opening session as main channel
. 2018-09-18 14:40:51.233 Opened main channel
. 2018-09-18 14:40:51.236 Started a shell/command
. 2018-09-18 14:40:51.256 --------------------------------------------------------------------------
. 2018-09-18 14:40:51.256 Using SCP protocol.
. 2018-09-18 14:40:51.257 Doing startup conversation with host.
. 2018-09-18 14:40:51.269 Skipping host startup message (if any).
> 2018-09-18 14:40:51.270 echo "WinSCP: this is end-of-file:0"
< 2018-09-18 14:40:51.294 ExtremeXOS
< 2018-09-18 14:40:51.294 Copyright (C) 1996-2016 Extreme Networks. All rights reserved.
< 2018-09-18 14:40:51.294 This product is protected by one or more US patents listed at http://www.extremenetworks.com/patents along with their foreign counterparts.
< 2018-09-18 14:40:51.294 ==============================================================================
< 2018-09-18 14:40:51.294 Press the <tab> or '?' key at any time for completions.
< 2018-09-18 14:40:51.294 Remember to save your configuration changes.
< 2018-09-18 14:40:51.294 ******************************************************************************
< 2018-09-18 14:40:51.294 MPLS NOTES:
< 2018-09-18 14:40:51.294 -PORT DESCRIPTIONS ARE INDICATIVE ONLY
< 2018-09-18 14:40:51.294 -USE LLDP / CDP / EDP TO ASSIST IN IDENTIFYING CONNECTED DEVICES
< 2018-09-18 14:40:51.294 -PHYSICAL PORTS SHOULD BE REMOVED FROM VR-DEFAULT
< 2018-09-18 14:40:51.294 -CUSTOMER HANDOFF PORTS SHOULD HAVE A L2PT PROFILE APPLIED (EPL/EVPL)
< 2018-09-18 14:40:51.294 -CUSTOMER HANDOFF PORTS SHOULD BE LABELLED "UNI"
< 2018-09-18 14:40:51.294 -CUSTOMER HANDOFF PORTS SHOULD HAVE CDP/EDP/LLDP DISABLED
< 2018-09-18 14:40:51.295 XXXX-PE01.1 # echo "WinSCP: this is end-of-file:0"
< 2018-09-18 14:40:51.296
< 2018-09-18 14:40:51.296 %% Invalid input detected at '^' marker.
. 2018-09-18 14:41:06.473 Waiting for data timed out, asking user what to do.
. 2018-09-18 14:41:06.473 Asking user:
. 2018-09-18 14:41:06.473 **Host is not communicating for 15 seconds.
. 2018-09-18 14:41:06.473 Wait for another 15 seconds?** ()
. 2018-09-18 14:41:27.704 Attempt to close connection due to fatal exception:
* 2018-09-18 14:41:27.704 **Terminated by user.**
. 2018-09-18 14:41:27.705 Closing connection.
. 2018-09-18 14:41:27.705 Sending special code: 12
. 2018-09-18 14:41:27.705 Sent EOF message
* 2018-09-18 14:41:27.727 (EFatal) **Terminated by user.**
* 2018-09-18 14:41:27.727 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
! 2018-09-18 14:41:32.898
Rowan Sakul
Looks like imported settings from Putty had a specific setting which caused the issue.
I just created a brand new session for the device using the defaults (including "File Protocol: SFTP"), which seems to work.
