Unexpected General Exception
Alex17
New Contributor II
Hi everyone!
Recently, one of ours Summit X450 of my network stopped working suddenly.
Checking booting messages, I got some errors like this:
ERRORPC=bfc00300EPC=bffff7ff
PANIC! Unexpected General exception!
ERRORPC=bfc00300
EPC=b1c0b1cc
Has anyone ever experienced this ?
We need to recover the cfg file, since we haven't backup the configuration.
Thanks in advance!
Best Regards,
2 REPLIES 2
Vellachery__Sum
Alex,
These messages seems to be a hardware failure, we could try booting the switch from an alternate partition and see if it helps.
Please click on the below mentioned Article to see the steps for booting the switch from an alternate partition:-
https://gtacknowledge.extremenetworks.com/articles/Solution/PANIC-Unexpected-General-exception
In case, if its not helping you to recover the switch, we would need to RMA the switch. Open a case with our TAC team along with the session logs.
Note:- I don't think, we would be able to recover the switch configuration. The above article only helps you to recover the switch. In case, if you have an old show tech or a working configuration file, we could copy paste the configuration to the switch, once it is recovered.
Regards,
Sumeesh
André_Herkenrat
You open a case with our TAC to get a new 450 in exchange for the defective one, but I doubt that you can recover the config of the switch.
