Unfeasible routes if next-hop learn with OSPF
  • Question
  • Updated 5 years ago
Create Date: Apr 15 2013 9:12PM
Hello,
Have problem with unfeasible routes if next-hop was learn OSPF (XOS 15.2.2.7)
# sh bgp routes network 10.33.33.0/24
 Routes:
     Destination         Peer            Next-Hop        LPref Weight MED        AS-Path
u i  10.33.33.0/24       82.144.193.144  82.144.195.142  140   1      0          42982
u i  10.33.33.0/24       82.144.193.150  82.144.195.142  140   1      0          42982
u i  10.33.33.0/24       82.144.193.145  82.144.195.142  140   1      0          42982
u i  10.33.33.0/24       82.144.193.151  82.144.195.142  140   1      0          42982
Flags: (*) Preferred BGP route, (>) Active, (d) Suppressed, (h) History
       (s) Stale, (m) Multipath, (u) Unfeasible
Origin: (?) Incomplete, (e) EGP, (i) IGP
BGP Route Statistics Matching the Display Criteria
  Feasible Routes   : 0
  Active Routes     : 0
  Rejected Routes   : 0
  Unfeasible Routes : 4
Next-hop at rib & reachable:
# rtlookup 82.144.195.142
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#o1  82.144.195.140/30  77.120.1.62     22   UG-D---um--f- vlan187    0d:1h:34m:42s
 in KB I'm find next  info
Goal: What makes BGP routes show as Unfeasible under the 'show bgp route all' command?
Why: Two reasons cause such behavior:
- Local VLAN is not ipforwading enabled (as below example).
- Route's next-hop is unreachable.
But
Local vlan ip forwarding:
# sh vlan vlan186
VLAN Interface with name vlan186 created by user
        Admin State:    Enabled         Tagging:        802.1Q Tag 186
        Description:    agg-1.f17 - cr-1.f17
        Virtual router: VR-Default
        IPv4 Forwarding: Enabled
        Primary IP    : 77.120.1.53/30
        IPv6 Forwarding: Disabled
        IPv6:           None
        STPD:           None
        Protocol:       Match all unfiltered protocols
        Loopback:       Disabled
        NetLogin:       Disabled
        QosProfile:     None configured
        Egress Rate Limit Designated Port: None configured
        Flood Rate Limit QosProfile:       None configured
        Ports:   1.       (Number of active ports=1)
           Tag:       *1g
        Flags:    (*) Active, (!) Disabled, (g) Load Sharing port
                  (b) Port blocked on the vlan, (m) Mac-Based port
                  (a) Egress traffic allowed for NetLogin
                  (u) Egress traffic unallowed for NetLogin
                  (t) Translate VLAN tag for Private-VLAN
                  (s) Private-VLAN System Port, (L) Loopback port
                  (x) VMAN Tag Translated port
Next-hop reachable:
#o1  82.144.195.140/30  77.120.1.62     22   UG-D---um--f- vlan187    0d:3h:58m:52s
# ping coun 3 82.144.195.142
Ping(ICMP) 82.144.195.142: 3 packets, 8 data bytes, interval 1 second(s).
16 bytes from 82.144.195.142: icmp_seq=0 ttl=63 time=24 ms
16 bytes from 82.144.195.142: icmp_seq=1 ttl=63 time=16 ms
16 bytes from 82.144.195.142: icmp_seq=2 ttl=63 time=16 ms
--- 82.144.195.142 ping statistics ---
3 packets transmitted, 3 packets received, 0% loss
round-trip min/avg/max = 16/19/24 ms
(from pacan4ik1_pacan4ik1)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
There are no replies.
